High mileage buy?
Old 07 Jan 2009, 05:16 pm
Default High mileage buy?
Hi everyone, my first post here. Sorry its a question!
We have a 2.2 Limited Diesel cruiser already which Mrs Oddie uses, but I've seen a 2 litre petrol Cruiser that I might buy for me. The only downside is that it has done 85,000 miles. I guess my question is, is that too high a mileage to consider? What kind of distance are the petrol engines good for?
I think it has been serviced regularly and has service history.
Thanks for any advice
Old 07 Jan 2009, 05:43 pm
crusierdad76's Avatar
Default Re: High mileage buy?
im gonna guess you are from the other side of the pond (we don't have the diesel PT's here shame but we don't) anyway there is a thread that is some thing like how many miles does you PT have---I don't think 85xxx is that many a lot of guys will go way over the 100.000 and not even think about it--- its not goning to get the mpg's of the diesel or probably have that kin of power but hry it is all we can get over here and we love them
Old 07 Jan 2009, 05:49 pm
Hi, you're right, we're here in the UK
I guessed that the engine should handle more than 100,000 with maintainence. It seems that a timing belt change is due round about 90,000 miles though??
Old 07 Jan 2009, 07:18 pm
well over here the timing belt is due between 90,000 and 100,000 cost bout $1000 which is just stupid high but it is what it is
the axle beaning or wheel bearings what ever you call them usually die as well way before they should
and along with the timing belt the water pump and maybe the oil pump I really haven't heard about a lot of other stuff other than just normal wear items
Old 07 Jan 2009, 08:54 pm
I purchased my 2001 LE a year ago with 116,000, it now has about 128,000 and is going strong. Other than oil changes, tires and such, I've had no other maintenance done.
Old 08 Jan 2009, 01:50 am
Thanks for the replies
I guess it should be OK then. Mrs Oddies diesel only has 32,000 on the clock so a higher mileage PT was something of an unknown quanitity to me.
Sounds good to go!
Old 08 Jan 2009, 03:53 am
monkey's Avatar
....be interesting to know if you go for it!!!!!!?.....Hmm,his & hers PT's....now do'nt get Mrs Monkey having any ideas will you!?
Old 08 Jan 2009, 04:38 am
The his n hers element puts me off somewhat ... but I was thinking of turning mine into an evil twin of Mrs Oddies ... lowered, bit of pinstriping, etc.
That could be cool.
Old 08 Jan 2009, 07:09 am
If you look on UKCruisers, there are lots of reports of suspension rubber "bushes" (I guess anything Bush whould be a clue at failure...) they call them (here it's bushings) that repair shops say need replacing. There is no similar high failure rate of them here...
Timing belt is major item at 90-100,000 miles.
I assume it's a manual, if it's an auto, be sure and have the transimssion fluid changed and be sure they use only ATF + 4.
If you can have it done, I'd have a mechanic look it over & do a compression check.
Old 08 Jan 2009, 07:51 am
monkey's Avatar
..talking of evil twins..Mrs M is one of a twin..I believe I married the good one which makes her sis the e....er,now hold on I think it might be time for an order of a spade for table monkey 'ere if I carry this on!!????....Think the idea of goin' a bit evil on yours would be a tip-top idea..my other car is definitely evil..I keep takin' out into the middle of no-where and it still hummerin' finds it way home
Mileage Report dcathy PT Cruiser Convertible Forum 10 28 Dec 2008 06:11 pm
BETTER Fuel Mileage for me MINIHEMI46 Turbo Performance 5 27 Mar 2008 07:29 am
2006 PT Limited Ed Mileage is terrible. vetteloverpa General PT Cruiser Discussions 45 11 Mar 2008 12:09 am
