The reason is quite simple, the green is less expensive and more readily available. ~CYCLONE_06 |
my wife's engine light came on this morning. when i checked under the hood the only thing out of fluid was the coolant. we did just give it an oil change sunday. i filled it up w/prestone (actually kind of overfilled a little) drove it around for a while and the light is still on. is that normal? will the light go off by itself? we did add prestone "works w/all fluid colors" coolant to the reservoir.
The engine light tells you that the computer has found a fault. Find out what the fault is before getting rid of the light. Here's how...
How to retrieve fault codes. When you retrieve the fault code and want to get rid of the light, take the negative battery cable off for about 5 minutes. That will clear the fault from the computer.
![]() 2008 Silver Steel Metallic, Touring, NA, Sirius; Chromed door handles; lower grille; fog light surrounds; chrome front & rear bumpers strips; Airaid air filter; Bassani duals; Modesty Cover; Autolite AP5263 Platinum Plugs (.040); Crane Plug Wires; NAPA Ceramic pads; Blane hood struts; PTeazer Gas, Brake & Foot Rest Pedals, '05 Rear Step Pad, Stainless Door Sills, Llumar tint, "A" Piller chrome; APC Strut Bar |
441 Evaporative purge flow system not working properly /// crewzin you rock. i will definitely remember that little trick. now to figure out how to fix the problem. any suggestions??
Error P0441
checked the solenoids and the middle one was actually not hook in place (it was loose) ASSuming i was looking @ the right spot. (up by washer fluid fill cap) 3 little, what look like plugs?? seem to be connected properly.
it says it has the same diethylene glycol & ingredients as the orange stuff. (it's also pre-mixed) |
| empty fuel tank, engine runs bad afterwards | autoenting | Tech & Performance Forum | 17 | 03 Sep 2010 04:36 pm |
| Faulty Engine Coolant Sensor? | thegoldpt | Tech & Performance Forum | 6 | 17 Jun 2010 08:14 pm |
| Error Code List | skylight | General Turbo Discussions | 6 | 07 Apr 2007 02:11 pm |
| "Mysterious" turbo engine noise...??? | Gary04GT | Turbo Performance | 76 | 21 Aug 2006 08:28 am |
| Review: $2200 for a NA replacement engine PT | Ctown | General PT Cruiser Discussions | 8 | 24 Jul 2006 01:08 pm |
