engine coolant reservoir empty?
Old 12 Jan 2009, 04:00 pm
Default engine coolant reservoir empty?
this reservoir doesnt seem to have anything in it...
engine temp hasnt been over half, no burn smells or any lights.
the cap says "special" coolant ...
is there anything i can do ?
2006 PT 37K 20MPG
Old 12 Jan 2009, 04:24 pm
Default Re: engine coolant reservoir empty?
The reservoir is hard to see and the coolant (red) isn't dark so make sure you are low before putting more in. Chrysler uses a red coolant and wants you to use the same kind when refilling.
2000 PT. 100,000 miles, Original Owner
Old 12 Jan 2009, 05:57 pm
Alright, got a long 20inch strip of thick paper and shoved it in the coolant reservoir,
this is what came out
it probably scraped on the bottom of the container
there is no liquid in there...
that gunk is a dark green-gray gunk ... buggers
i also bought a jug of Prestone dex-cool 50-50 from Autozone (i asked for "the orange one" as the Chrysler mechanic told me over the phone)
is it ok to pour it in the reservoir, or would it push the crud down some pipes?
2006 PT 37K 20MPG
Old 12 Jan 2009, 06:06 pm
By your screen name, i take it you have a 2006 PT? Did you buy it used? If so, you don't know the cars history, right? You shouldn't have "gunk" in a 2 year old car. What's the water/coolant look like when you take the radiator cap off. Don't take it off if it's hot please.
Old 12 Jan 2009, 06:13 pm
Hi Crewzin,
yup 2006, bought it from a used car dealer, all i know so far is it was an Enterprise car.
engine is still hot now, i'll check the radiator in about 30 minutes.
2006 PT 37K 20MPG
Old 12 Jan 2009, 07:59 pm
alright, radiator cap off,
i see a "clean" (i dont see any dirt or stuff in it)
its an opaque dark orange liquid when i look at in the radiator hole.
spread on white paper it looks clear orange
2006 PT 37K 20MPG
Old 12 Jan 2009, 08:13 pm
CYCLONE_06's Avatar
Send a message via AIM to CYCLONE_06 Send a message via Yahoo to CYCLONE_06
I had a buddy of mine suck all the orange crap out, and switched mine over to green. I asked an expert what the difference was, and he said just the color. He said prestone has the same silicates and such in it to prevent rusting.
I also had some of that brown stuff around the top of the resevoir, I just took a hose and over flowed it until it was completely clean.
~CYCLONE_06
"It's been said winning isn't everything... Just not by me."
--Mark Martin
Old 12 Jan 2009, 08:59 pm
Sounds like it's OK to just add what you bought to the reservoir. If you can, like cyclone just said, get as much of the "gunk" out as you can.
Old 12 Jan 2009, 09:03 pm
great, thanks Crewzin, Cyclone_06 !
2006 PT 37K 20MPG
Old 12 Jan 2009, 09:24 pm
You've gotten good advice.
I just want to add a bit more. If you fill the overflow tank when engine is warm, go to the top line in the tank. If the engine is cold when you fill, go to the bottom line.
Check on it after you've driven a while - since tank was empty, you MAY have air in you system and it may "drink" some coolant.
That the coolant was to the top of the radiator is good.
There is no harm if you put too much coolant in the overflow tank - it'll possibly overflow to the ground when engine gets hot, that's all.
empty fuel tank, engine runs bad afterwards autoenting Tech & Performance Forum 15 15 Jan 2009 02:22 pm
"Mysterious" turbo engine noise...??? Gary04GT Turbo Performance 76 21 Aug 2006 08:28 am
Review: $2200 for a NA replacement engine PT Ctown General PT Cruiser Discussions 8 24 Jul 2006 01:08 pm
Faulty Engine Coolant Sensor? thegoldpt Tech & Performance Forum 5 06 Jul 2005 12:14 am
  Wordpress Theme | Debt Consolidation | Debt Consolidation | Debt Consolidation | Deaf Topics
