2001 Wont start. Freshly charged battery
Old 17 Jan 2009, 07:10 pm
Default 2001 Wont start. Freshly charged battery
It's been -20 here the past 2 days and I couldnt get my car to start. This happens every year when it gets this cold here. Last year I pulled the battery out and took it to get charged and it worked again. This year same deal, wouldnt start... pulled the battery, had it checked. It's 2 years old and works fine. Full charge... a bit warmer today (10-20) and it still wouldnt start. I really dont know much about cars aside from a few things I taught myself because I got sick of tossing away money on this thing. Any suggestions? Starter? Spark plugs?
I have over a half a tank of gas, tried adding heet and that didnt work either.
Thanks
Old 17 Jan 2009, 07:49 pm
Default Re: 2001 Wont start. Freshly charged battery
Welcome to the forum. If it doesn't even try to turn over and the battery is good, it could be that the starter or solenoid is frozen up. I take it you checked all the main fuses. If it's turning over and not starting, could be you gotten some water in the gas line and that's frozen.
Old 17 Jan 2009, 08:45 pm
it turns over but doesnt fire. I ran a bottle of heet through the gas tank as well. If it is a frozen fuel line what are my options? Should I pretty much expect to have to get it towed monday?
Old 17 Jan 2009, 08:59 pm
If that is your problem, and it's hard to exactly pinpoint it right now, and you need your PT for transportation now, then yes, you'll have to have it towed to a garage to find out exactly what's wrong.
If it's turning over slowly you may just need a jump from a fresh battery to get enough juice/power to turn it over fast enough to start.
Old 19 Jan 2009, 02:14 pm
I'd open the air intake and spray some starting fluid in - if that doesn't fire, then your problem is spark...
2001 Limited Stalled Will Not Start Macguyver General PT Cruiser Discussions 19 24 Nov 2011 11:23 am
BATTERY ISSUES!!! STREAT23 General PT Cruiser Discussions 12 14 Feb 2009 08:38 pm
Time For New Battery BB Turbo Performance 11 11 Jan 2009 11:21 pm
problem with the PCM after battery replacement MrDove Tech & Performance Forum 8 11 Aug 2008 06:04 pm
My 2001 PT won't start! envision_man Tech & Performance Forum 4 29 Jun 2004 08:30 am
