no heat
Old 19 Jan 2009, 12:01 pm
Question no heat
new here, got a problem. 01 pt
Had a new TIMING BELT, WATERPUMP,RADIATOR ,THERMOSTAT installed and now have no heat
Had good heat before work was done
Coolant level is good
All hoses are hot
Coolant is flowing fine and has been driven about 50 miles so I dont think any thing is air bound
Air blend door does move
Runs fine
Temp gauge is where it always was before repair/ half way
ANY IDEAS
Old 19 Jan 2009, 02:38 pm
Default Re: no heat
Sounds to me like air in your heater core - unfortunately, I don't know how to get it out....
Old 19 Jan 2009, 04:59 pm
Default Re: no heat
The heater core has the same water as the rest of the system. Take it back to whoever did the timing belt and have them bleed the system of the excessive air. You'll also have overheating problems so watch the temperature guage.
Old 20 Jan 2009, 10:50 am
Default Re: no heat
I dont think it is air, the system has a good flow when hot
Old 20 Jan 2009, 11:03 am
crusierdad76's Avatar
Default Re: no heat
Ok but if that is truly the case then look at it this way
The water or coolant in the radiator gets hot--is that correct???
That same water/coolant is what runs through the heater core---????
if that water is at operating temp close to like 190degrees---then the heater core HAS to get hot if in fact there really is a good flow through the core.
Now if all this is true then the air that blows over the core has to be hot it is just that simple
if you are saying it is not then some how the core is not heating up
and if it is not heating up then there has to be a blockage some place be it air or whatever
So if all this is true and you have no heat then the core can not be getting hot
or the fan is not blowing over the core to send the heat into the cabin
maybe the flow you see is not going through the heater core????
I may have missed something but the way it seems is if the water gets hot, the core gets hot, the air gets hot, the car gets hot......................
Old 20 Jan 2009, 11:06 am
Default Re: no heat
ALL hoses are hot to the touch which would tell you that there is no blockage
Old 20 Jan 2009, 11:08 am
Default Re: no heat
wonder if something is blocking just the heater core?????? hard to belive but something has to be going on
Old 20 Jan 2009, 11:22 am
soonercruiser's Avatar
Cool Re: no heat
Heater hose may be a "by-pass" hose; so, being hot may not reflect the actual status of the heater core (what's going on inside the core). So..
-bad core or air in heater core.
I'm assuming that they flushed the coolant system...that's where you get the air and other junk in the system.
Frank, aka SOONERCRUISER,
Old 20 Jan 2009, 11:24 am
Default Re: no heat
Im still thinking that the core is not getting hot if it were the air would have to be wouldn't it?????
Old 20 Jan 2009, 11:52 am
Default Re: no heat
any one familar with the air blend door?
No heat since repir KIMS CRUZER Tech & Performance Forum 8 01 Aug 2007 12:35 pm
THE HEAT IS ON !! bobs turbo pt Non-PT Discussions 10 27 Jul 2006 05:44 am
Rough Idle with Heat on Carchrism5 Tech & Performance Forum 2 05 Dec 2005 11:14 am
heat and fan control ~ what to expect on 1 and 2 ? frances General PT Cruiser Discussions 7 22 Dec 2004 09:09 am
Arizona heat Geeksterman Turbo Performance 4 29 May 2003 07:08 pm
