Condensation inside taillights?
Old 17 Feb 2009, 01:31 pm
Default Condensation inside taillights?
Does anyone know how to prevent condensation from forming inside the taillights of my wife's '07 PT?
Ron
Old 17 Feb 2009, 03:02 pm
Default Re: Condensation inside taillights?
Are you sure you don't have a crack in the lenses letting moisture in that is then condensing from being heated by sun, a warm garage, etc? Can't tell where you live so those are only a guess.
I've had my '01 for over a year, it sits outside in the rain and snow (no garage), I've never had moisture of any type in the housings, so reason for question on crack in lenses.
2001 LE, Shale Green, Aftermarket Wheels, Shorty Antenna, AirRaid Cold Air Intake, Whelen Talons (amber/white) in front windshield, Whelen Talons (amber) in rear side windows, Tomar RECT25's (amber) and Whelen Slimlighter(amber) in back window. Kenwood TK-880H 45 Watt Mobile Radio, Antenex 3db antenna w/ NMO mount.
http://smg.photobucket.com/albums/v7...0PT%20Cruiser/
Old 17 Feb 2009, 03:06 pm
Take the taillights out (one screw) and check the connections of the bulb holders to make sure they are tight and also look at the back of the lights the same as Garyerrol just said, for cracks in the back of the lights and around the edges.
Old 18 Feb 2009, 09:31 pm
Thanks guys, I'll give it a look this weekend.
By the way, we're in North Carolina, near Charlotte.
73, Ron w4ron
Old 18 Feb 2009, 09:39 pm
soonercruiser's Avatar
Cool Re: Condensation inside taillights?
When the bulb socket is turned and locked into place, there should be a plastic or rubber washer there to "seal" the bulb socket area. You could remove the washer (making sure there is one there) and lube both sides with vaseline or dielectric grease to be sure there isn't a leak.
-Otherwise, it's a cracked plastic lens, unless proved otherwise.
Frank, aka SOONERCRUISER,
Old 22 Feb 2010, 06:28 pm
I'm having this same problem with my '08, only it's on the front left headlight. The daytime running light has gone out and I noticed a lot of moisture under the headlight cover today. Is there just one screw holding the front headlight in place and how difficult will it be to replace the light and correct the problem? Thanks for any help in advance.
Old 22 Feb 2010, 07:05 pm
The front headlights are a different matter. A lot of work to replace those. Check the bulb connections first, just like the tail lights. There's a flap in the front wheel wells. Remove the flap for access to the head light bulb connections and check to make sure they are sealed properly.
Old 22 Feb 2010, 07:13 pm
Thank you SO much Crewzin! Now I just have to relay that info to my son and wait for his schedule to open up to fix it.
rocket taillights Megalon Exterior Accessories Forum 13 11 Jan 2008 10:48 pm
Washed the inside of the taillights too! zzzhuh General PT Cruiser Discussions 10 28 Jan 2006 05:56 pm
APC tails condensation problem fixed coopj40 General PT Cruiser Discussions 5 01 Apr 2004 08:33 pm
Taillights mcruz Exterior Accessories Forum 8 02 Jan 2004 06:38 pm
Euro Light Condensation Mr.Blonde General PT Cruiser Discussions 4 05 May 2003 05:56 pm
