Seeking 2002 LTD glass/window specs & replacement adivce
Old 23 Feb 2009, 01:22 am
j3s j3s is offline
Default Seeking 2002 LTD glass/window specs & replacement adivce
I'm a long-time lurker of the forums who finally found a reason to register, albeit not under the greatest of circumstances.
My 2002 Limited Edition was broken into last night, and I now need to have my rear passenger window replaced. Not having been through this with the PT before, I figured I should play it safe and seek some answers and advice beforehand
First, does anyone happen to know the specs for the window (manufacturer/style) in question? With a bit of Googling and searching the forum, I was able to find this information for the 2003 models, but nothing as far as the 2002's are concerned.
Secondly, since I will likely go the standard route of having the work done at an auto glass shop as opposed to the stealerhsip, are there any precautions I need to take when choosing one in order to make sure the replacement window matches the original, both style and colour/tint-wise? Likely just first-time replacement fears, but I just want to make sure I don't somehow end up with two completely different coloured windows on either side of the car.
Thanks in advance for any assistance or suggestions provided.
Old 23 Feb 2009, 02:01 am
BLUEH20's Avatar
Default Re: Seeking 2002 LTD glass/window specs & replacement adivce
If you go to the dreaded "stealership"--you will be able to get genuine OEM form/fit/function glass for your vehicle.
You can have it installed where every you chose.
Of course if you go to an indy/3rd party and chose a third party supplier; it is possible that your new non-OEM glass might kind of/sort of be exactly the same form, fit and function as originally installed.
If you do not have security/tinted glass your possible issues are greately reduced.
I live in a rather small community, some 59,000 residents, and just had the pleasure of getting the backlite glass replaced on my 2008. We have a small shop so all glass work is subleted--the "Dealership" flat rate is $65.00/hr and the indy glass shop flat rate is $76.00/hr. Neither shop charges for "cure time".
