engine change
Old 04 Mar 2009, 01:35 pm
Default engine change
I am converting a 2001 into 2dr panelvan. It has 180000 miles, I would like to change out the engine for a lower milage one. How new of a model year could I put in without a lot of wiring trouble? Are there certain years to avoid? It is a 5sp manual. thanx
Old 04 Mar 2009, 07:16 pm
Default Re: engine change
Might as well rebuild the '01 seeing as how you'll be spending the money on an unknown used one.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 05 Mar 2009, 07:42 am
Mean Green that sounds very wise. The replacement engine most likely will need work done. The orig engine is happy in there and re built will be like new. Andy
http://
Old 05 Mar 2009, 09:19 am
Also all of the emission equipment will be consistent with what you had.
Old 05 Mar 2009, 10:41 am
crusierdad76's Avatar
I checked out having a 2.2 Chevy and it was right at $2000 im not sure if a 2.4 is much higher but the guy doing the rebuild was also giving a 100,000 mile warranty "IF HE DID THE OIL CHANGES AND NEEDED MAINTENANCE" sounds like a good deal to mew
Engine swap / replacement compatibility Brent72 Tech & Performance Forum 2 28 Jan 2009 07:23 pm
2004 PT cruiser Engine light on and Knocking moonfairy16 Tech & Performance Forum 13 18 Dec 2008 03:32 pm
NOISY ENGINE!!! ncrow02 Tech & Performance Forum 2 05 May 2008 12:52 am
"Mysterious" turbo engine noise...??? Gary04GT Turbo Performance 76 21 Aug 2006 08:28 am
Review: $2200 for a NA replacement engine PT Ctown General PT Cruiser Discussions 8 24 Jul 2006 01:08 pm
