HEADLIGHT ANTI FOG KIT??
Old 09 Mar 2009, 06:20 am
mjb457's Avatar
Default HEADLIGHT ANTI FOG KIT??
Ok I read on hear that there is a kit to clean up the front lens covers that seem to discolor(fog) over time..where can it be bought at?? Thanks MJB (Or can it be done with home products?? )cheaper,,,,,,,,,,,,,,,
Old 09 Mar 2009, 08:03 am
Default Re: HEADLIGHT ANTI FOG KIT??
Hello I have tried several things in the past and the best thing I have found is the XXX.bestheadlightcleaner.com Just replace the xxx with WWW. I found it at Walmart for 20 couple dollars.
Old 09 Mar 2009, 09:55 am
Permatex makes a kit available at Advance Auto parts, and Pep boys. A series of wet sanding high grit sandpaper, then a final polish. It works very very well and costs $20. WIthin a year they well again be fogged. A sealant is needed.
Old 09 Mar 2009, 11:31 am
Someone posted on here a few weeks ago about just such a product. You sanded, wiped it down, sanded some more, more wiping, then put on a sealant, I believe two applications and you were done. When it warms up a bit more, I'm going to try it on mine. It's not so much that I think the light output has diminished a lot, it's more that the headlights look crappy when clouded over on an otherwise great looking Cruiser.
2001 LE, Shale Green, Aftermarket Wheels, Shorty Antenna, AirRaid Cold Air Intake, Whelen Talons (amber/white) in front windshield, Whelen Talons (amber) in rear side windows, Tomar RECT25's (amber) and Whelen Slimlighter(amber) in back window. Kenwood TK-880H 45 Watt Mobile Radio, Antenex 3db antenna w/ NMO mount.
http://smg.photobucket.com/albums/v7...0PT%20Cruiser/
Old 09 Mar 2009, 03:03 pm
StoneWhitePT2's Avatar
The ultimate cure is New Headlights... And to keep them waxed right along with the car. The Sun's UV rays are no joke!!
--See My PT In Action!!! http://www.youtube.com/watch?v=ppP_V9udtho
2002 Custom Dream Cruiser Series 5 Rollin 22s/20s
Old 09 Mar 2009, 04:53 pm
I agree, however at eighty to ninety dollars a light, twenty to twenty-five dollars for a kit that if done right will make them almost look, if not, new sounds awful tempting to many of us.
Old 09 Mar 2009, 07:17 pm
My company just did a video on this subject it will air on old cars television in the Spring...go to Well-Worth Products, Inc. go to products and click on the coating section...you will see a product that is called see well headlight...This is a PROCESS. You have to tape off the area around the headlight and SAND the polycarbonate. Then you spray an actual UV coating on the headlight...Then the headlight has to sit facing the sun to cure as most of us don't have a UV cure light kicking around in their garage. WOW it looks like new. We have tried all different kits/chemicals etc...as we do this for warranty at the dealer. This is the best!!! Any questions, LeakPro Intro Page
I have tried about 12 different chemicals from different companies and none work like this well worth product. I don't sell it, so I will always give an unbiased opinion as you know from my various posts. John
Old 09 Mar 2009, 08:05 pm
Well I would say save up for new lamps. There is always ebay too where you can find some for a decent fee new or used...
Old 10 Mar 2009, 09:25 pm
Walmart just starting offering a service to repair headlights. I think the charge is $40 and they get excellent results.
Old 11 Mar 2009, 07:20 am
I used this on my son's '98 car - worked great - and it has a sealer:
http://www.crystalviewchemicals.com/...ght/index.html
Site doesn't come up now, but I've read some found it at AdvanceAuto.
Replacing Headlight Bulbs whitbyPT Exterior Accessories Forum 22 06 Nov 2010 06:33 pm
Headlight Removal/Replace 2k1PT General PT Cruiser Discussions 7 31 Aug 2008 05:36 pm
Drivers Side Headlight 2k1PT Classifieds: Want To Buy 2 23 Aug 2008 03:39 pm
Headlight Lens Issue kalyhan General PT Cruiser Discussions 8 23 Apr 2008 05:04 pm
Anti Sway Bar Question skydive69 Tech & Performance Forum 11 12 Nov 2002 01:52 am
