been getting engine light on with no codes for a while, about every 70 miles
today codes show up p0138 p0122
2006 PT 37K 20MPG
P0138 = P0138 HO2S Circuit High Voltage Bank 1 Sensor 2
Not a lot on the P0122 s far as fixing it. You might need special diagnostic tools/scanner. Here a list of codes separated by what they go to.... TROUBLE CODES, Page 3
cool, thanks guys, now i have something to show the technician
(i hope some will be covered by my extended warranty) hmmm while im there i could also give him the Crane wires & plugs to change
2006 PT 37K 20MPG
ok, they say they're gonna do the O2 sensor - cost me 220
im also getting some cold start squealing ("2 belts") gon' cost me another 220 and here's some other prices i asked about front brakes 279 plugs+wires 220 (i forgot if that's using my wires or not) Trans flush 189 Coolant flush 189 how does that sound?
2006 PT 37K 20MPG
no i think its just 1 sensor, the one they're getting the code for
also they say they are only getting one code from memory - O2 code arent a number of previous codes stored in the cars putter? its is indeed dealer service, but i need my car back so i havent had time to look around...
2006 PT 37K 20MPG
The codes stored in the computer are all of the codes that are set by previous sensors unless the battery is disconnected for about 5 minutes or a dealer or private mechanic with a scanner has cleared them. Then you start all over with new codes that are seen.
230 miles later p0122 pops up again ...
(along with a p2074, 0138 still there and the 0122) ![]() ------------- p2074 google as P2074-manifold Pressure/throttle Position Correlation CORRELATION - HIGH FLOW/VACUUM LEAK When Monitored: Engine Running, during all drive modes. Set Condition: If vacuum drops below 1.5 Hg with engine RPM greater than 2000 RPM at closed throttle. POSSIBLE CAUSES VACUUM LEAK HIGH RESISTANCE IN MAP (K7) 5 VOLT SUPPLY CIRCUIT RESISTANCE TO GROUND IN MAP (K7) 5 VOLT SUPPLY CIRCUIT MAP SENSOR HIGH RESISTANCE IN (K1) MAP SIGNAL CIRCUIT RESISTANCE TO GROUND IN (K1) MAP SIGNAL CIRCUIT HIGH RESISTANCE IN (K4) MAP GROUND CIRCUIT PCM TP SENSOR OPERATION HIGH RESISTANCE IN (K6) TP SENSOR 5 VOLT SUPPLY CIRCUIT RESISTANCE TO GROUND IN (K6) TP SENSOR 5 VOLT SUPPLY CIRCUIT TP SENSOR HIGH RESISTANCE IN (K22) TP SIGNAL CIRCUIT RESISTANCE TO GROUND IN (K22) TP SENSOR SIGNAL CIRCUIT HIGH RESISTANCE IN TP (K4) SENSOR GROUND CIRCUIT ------------- doesnt sound like it would have anything to do with the oxygen sensor? ... why would the same oxygen sensor code show up again?
2006 PT 37K 20MPG
1. Maybe the original codes weren't cleared from the computer. 2. The vacuum leak is messing with the air/fuel mixture and the upstream 02 sensor is picking that up as a fault.
| Error Codes | skylight | Tech & Performance Forum | 7 | 28 Apr 2011 03:34 pm |
| Error Codes | thegoldpt | Turbo Performance | 6 | 07 Apr 2007 02:26 pm |
