platinum Number
Old 24 Mar 2009, 01:32 am
Default platinum Number
I ordered Champion Platinum from USA and was shipped #3570 I read somewhere it should be 4575 or 70 shoud I install the 3570 shipped or trash them and re order. Hate to install then have do it over--- Andy
http://
Old 24 Mar 2009, 06:28 am
Default Re: platinum Number
If your talking about Champion Double Platinum, the old number was #7440 which was replaced with #7570.
If there is Single Platinum, maybe your number is correct but the only plugs we've been talking about are the doubles.
Old 24 Mar 2009, 10:36 am
Cruzin,would you advise trash and re order or use them? Andy
http://
Old 24 Mar 2009, 12:21 pm
I did some searching and what I found was from the SRT forums. They list the 3570 as a Single Platinum plug and the 7570 as the Double. If that's true, you can use the 3570 BUT, I just read this (below) and it says not to use Single Platinum plugs in a "waste spark" DIS ignition system (which is what we have because we have a double coil and 4 cylinders therefore a spark is wasted. So, I would take them back and get the Double Platinum #7570.
Don't Use Standard or Single Platinum Spark Plugs with Waste Spark DIS Ignition Systems
Old 24 Mar 2009, 03:41 pm
Thank you so much I am not good enough with computers to look things up--Andy
http://
Front number plate junkno General PT Cruiser Discussions 4 23 Oct 2004 03:51 am
platinum plugs airevac19 Tech & Performance Forum 5 21 Apr 2004 11:30 am
Part number for a Stage 1 Iggy Stage Turbo Kits 3 06 Oct 2003 09:26 pm
recal question midnight03 General Turbo Discussions 17 27 Sep 2003 07:06 pm
Platinum Plugs Not Tex Tech & Performance Forum 10 28 Jun 2002 07:12 pm
