car wont turn on.
Old 03 Apr 2009, 03:28 pm
Default car wont turn on.
hi guys. i have a 2001 pt Cruiser and the car one day turned on and off the radio and once i parked never turned back on.
ive replaced the crank and camshaft sensors.
the ecu and alt.
the ppl at the dealer are saying i need to change the whole harness of the car is this true?
it has fuel pressure but no spark.
what can i do? the timing is perfect too.
Old 03 Apr 2009, 03:55 pm
Default Re: car wont turn on.
anyone?
Old 03 Apr 2009, 04:19 pm
The engine won't run or the radio won't come on???
Old 03 Apr 2009, 04:20 pm
engine cranks but wont run.
Old 03 Apr 2009, 04:29 pm
any idead that can save my pocket?!
Old 03 Apr 2009, 05:32 pm
Its a long shot, but you didn't mention how many miles you have on it, but did you check the timing belt, I know you mentioned the timing is perfect but is the belt on? Have you had the car from brand new or did you get it used?
Old 03 Apr 2009, 06:52 pm
How do you know the timing is perfect if it won't start? I thought the engine had to be running to check timing?
2001 LE, Shale Green, Aftermarket Wheels, Shorty Antenna, AirRaid Cold Air Intake, Whelen Talons (amber/white) in front windshield, Whelen Talons (amber) in rear side windows, Tomar RECT25's (amber) and Whelen Slimlighter(amber) in back window. Kenwood TK-880H 45 Watt Mobile Radio, Antenex 3db antenna w/ NMO mount.
http://smg.photobucket.com/albums/v7...0PT%20Cruiser/
Old 03 Apr 2009, 08:42 pm
i checked the timing by pulling the cover on the belt and checking. it all perfect.
car from new. has 90k miles on it
Old 05 Apr 2009, 09:24 pm
i put the crank sensor new and the car still gives me the code
Old 06 Apr 2009, 07:29 am
What code are you getting?
Turn key "on" (right before start)
Back one click to "off"
On
Off
ON
in mileage display you should see one or more codes like P0402 and then done - you should always get at least "done".
Post what codes(s) you get.
Fog lights won't turn off... emhymas Tech & Performance Forum 21 08 May 2010 03:52 pm
Noise in front when making left turn; not right Runkle Wheels, Tires, Suspension 2 12 Feb 2007 01:04 pm
Turn Signals Not Working Indynick General PT Cruiser Discussions 9 15 Sep 2004 02:25 pm
Turn signal & stop light gonzomania General PT Cruiser Discussions 12 25 Apr 2004 01:18 pm
Key will not turn relytgerg General PT Cruiser Discussions 11 17 Feb 2004 02:36 pm
