Timing
Old 05 Apr 2009, 03:52 pm
Default Timing
Is it possible to visually check to see if all 3 timing marks are lined up, without pulling the entire side of the motor apart? I know that there is the small plug that you can pull in the center of the top timing belt cover, for the cam sprockets, but how about the crank mark?
2002 PT Cruiser, stock.
Thanks.
Old 06 Apr 2009, 07:28 pm
Default Re: Timing
Come on, anyone?
Timing Belt Replacement MarkB Tech & Performance Forum 38 30 Apr 2010 07:38 am
02 2.4L timing belt problem ronwins3 Tech & Performance Forum 18 15 Dec 2008 08:57 pm
loose timing belt and gears not moving - urgently need help pls. lanies_ptcruiser02 Tech & Performance Forum 12 12 Aug 2008 05:36 am
Another timing belt question thread :) ??? Ctown General PT Cruiser Discussions 4 24 May 2005 08:50 am
