Code P0441
Old 07 Apr 2009, 10:19 pm
Default Code P0441
Hello everyone! I have a 03 Pt Cruiser Dreamcruiser with 62K miles on it.
I got a check engine light on and the error code that came up is:
P0441 which says Evaporative Purge Flow System not working properly.
Any insights as to what I can do to fix this (cheaply if possible).
Thanks!!!
Old 08 Apr 2009, 05:20 am
Default Re: Code P0441
P0441 Evap Purge Flow Monitor -Insufficient or excessive vapor flow detected during evaporative emission system operation.
A Diagnostic Trouble Code indicates that the Powertrain Control Module has recognized an abnormal condition in the system. DTC's are the results of a system or circuit failure, but do not directly identify the failed component or components.
Possible causes for P0441 include:
Intermittent Condition
Checking Evap Purge Solenoid Functionality
Evap Purge Solenoid Vacuum Supply
You will need a DRB III scan tool and diagnostic manual to troubleshoot the issue.
Old 08 Apr 2009, 05:25 am
It's often the gas cap - either not seated properly or you need a new one.
Here's some reading for you:
WikiAnswers - What does a code P0441 EVAP emission mean on a 2003 dodge neon purge flow fault
Old 08 Apr 2009, 07:57 pm
Crewzin,
Thanks for the info. Is this scanner available at a local parts store like autozone or do I need a dealership service to get it checked?
Thanks!!!
Old 09 Apr 2009, 07:02 am
Originally Posted by AkiraCruiser View Post
Crewzin,
Thanks!!!
Yes it is available at the dealer but any decent mechanic at a decent repair/maintenance facility will also have one and charge a lot less per hour to diagnose your PT.
the dreaded p0551 code - stumper djfox1 Turbo Performance 9 27 Jun 2011 03:31 pm
Code 2094 Camshaft Position Actuator bank 2 low PTGUY_PSL Tech & Performance Forum 0 27 Dec 2008 08:46 pm
Error code trouble P0132, 1686, 1687, 1681 SolidusGorto General PT Cruiser Discussions 0 19 Jun 2008 07:59 am
Dark Plum paint code ChaosTheory The Detail Shop 3 18 Mar 2008 11:03 pm
P0441 error code apollobey Tech & Performance Forum 2 07 Oct 2005 09:38 am
