How Do I Install Head lights in my 04 pt.
Old 17 Apr 2009, 08:56 am
Default How Do I Install Head lights in my 04 pt.
i saw in the manual how to change the lights under the wheel well.but the manual just says take off the cover.well i spent an hour trying to get it off.can someone please give in more detail or even a diagram how to change the lights.
Old 17 Apr 2009, 09:02 am
Default Re: How Do I Install Head lights in my 04 pt.
You'll have to jack up the car on the side your working on and turn the wheel towards the other side to give you room to work. Either that or jack up the car and take the wheel off.
In the wheel well there's an oblong piece with small flaps all around it. Take a flat head screwdriver and carefully work your way around the flap pulling it towards you until the whole flap comes off. That will give you direct access to the rear of the lights.
Old 17 Apr 2009, 01:10 pm
theres also little nuts.unscrew those right?what about like screws but they look like buttons?
Old 17 Apr 2009, 01:40 pm
Location: Belleuve, WA from Los Angeles - Road Rage specialist
No nuts to take out. Look upward from those screws at the bottom of the fender, there is a trap door so to speak, its a square just before the top crest of the wheel well. Start at the front of the inside of the fender feel your way upward and you will feel it, more inside than out. You can use a screwdriver to pull that door open enough to get your hands in there to pull it out.
Then you can reach in and twist then pull the bulb out through that door. Be gentle you are not given a lot wire to work with.
If you are ridng on stock 16's you may not have to jack the car up, but cut the wheels hard right to work on the left and vice versa. But even I find with my girls hands I sometimes need to at least jack the car up to get enough room to work with 17's and bigger custom wheels.
The silver 03 GT is gone, but a Solstice has arrived. There are three more PT's to play with though
My personal thanks to veteran and novice crewbies that have offered information and how-to's they have been instrumental in taking LiquidPT from modded car to stock to live a more quiet and sedate life.
Old 17 Apr 2009, 02:17 pm
thank you very much.it helps alot.i was thinking i had to take he front wheel are off.like that plastic area.but thanks.
Old 17 Apr 2009, 07:31 pm
Cool glad we got that cleared up what panel you were looking for. But pulling the wheel or not pulling it, gets answered pretty quickly. Either your paws fit or they don't. I know on my N/A I can swap bulbs out, my GT NO WAY. I run way to fat a tire on the 17's.. It looks good though
Old 20 Apr 2009, 02:26 pm
yea i found out how to install them.ok no the fog lights.under the usual bumper its just a gray covering.and i ordererd just the bulbs.will i have to buy a cover for them?
Old 20 Apr 2009, 03:26 pm
You shouldn't have to buy anything except the new bulbs, the covering comes away (you might have to hold it away) and them just put it back after you change bulbs. The covering is waht protects the end of the bulbs from debris.
Old 20 Apr 2009, 07:58 pm
^^ X2
No head or tail lights Pila Tech & Performance Forum 5 31 Dec 2010 06:51 pm
Head Lights Art Rigby Tech & Performance Forum 2 02 Oct 2007 02:22 pm
projection head lights jaspersnowstorm Exterior & Interior Styling 2 15 Apr 2005 09:32 am
anyone ever install fog lights?? bobs turbo pt General PT Cruiser Discussions 7 24 Sep 2003 10:01 pm
