Problems with my cruiser
Old 21 Apr 2009, 08:50 pm
Default Problems with my cruiser
Ok here goes. 02 pt cruiser, stock. Blew timing belt, fixed it. made sure all timing marks were perfect. started right up. put 15 miles on it, no problems. parked it for 3 days and would only turn over. started replacing stuff, battery, cam position sensor, crank position sensor, coil pack. pulled the front covers and all timing marks still line up. All the sudden it starts up, but really hard when cold. then when warm it idles fine but when you hit 2500 rpm it wants to cut out, like a limiter kicks in. as soon as you hit that 2500 rpm it throws the cps code. I am totally stumped. I'm now laid up, post shoulder surgery. i was hoping to get this thing figured out, but ran out of time. now my father in law is tryin to help me out with the wrench turnin. I need your help guys.
Thanks, Tyson
Old 23 Apr 2009, 09:29 pm
Default Re: Problems with my cruiser
Sounds like it either skipped a tooth or wasn't exactly right on (the timing belt).
I had valve damage when my wifes went while she accelerated from a light (about 15mph) no1 had 2 bad exhaust valves and 1 intake, machine shop did em all just to be sure.
Do you know that your valves are OK? I can't imagine you drove it for 15 miles with bent valves...
spark, fuel/air, and compression. Got em all?
Old 25 Apr 2009, 05:27 am
What is the "CPS code" you mention? That would seem to be the clue.
Old 25 Apr 2009, 07:52 pm
"CPS code" = crank position sensor code displayed. Timing marks all verified for a third time. new, used computer installed. Ideas running out.
2004 Chrysler PT Dream Cruiser Series 3 skylight PT Cruiser News and Rumors 10 18 Jun 2009 08:57 am
Exterior Mod List slayerdarkcross Exterior Accessories Forum 8 22 Jul 2008 03:54 pm
2006 PT Street Cruiser Route 66 Edition skylight PT Cruiser News and Rumors 35 17 Nov 2007 02:39 pm
'02 Cruiser with lots of problems :( slpknt2886 Tech & Performance Forum 4 07 Aug 2007 02:17 pm
New 2005 Convertible PT Dream Cruiser skylight PT Cruiser News and Rumors 4 11 Jan 2005 06:12 pm
