new pt owner with a few questions
Old 07 May 2009, 07:05 pm
yaris's Avatar
Default new pt owner with a few questions
hi, I just got a 2006 pt a couple of days ago and for now I love it. But I have a few question:
1-is there any common problem with thems or things to specially check regulary?
2-is the window washer fluid tank under the hood providing washing fluid for the rear window too or is there another separate one?
3-is there a place where we can check the window washer fluid level other than by the filling hole in the left corner of the hood?
thanks in advance for your responses and sorry if this has been answered before I searched but didn't find the answers I were lokking for
Old 07 May 2009, 08:10 pm
Location: Belleuve, WA from Los Angeles - Road Rage specialist
Default Re: new pt owner with a few questions
FWD Control arm bushings are a known week spot. Replace with polyurethane bushings never worry about it again. OEM brakes are known to dust lots and not really last long. So upgrade to better OEM replacement stuff and you will gain cleaner wheels and better stopping power. Gas milage is never going to be great, but you gain a very safe car in a crash - being a heavy pig does have an advantage in a crash. Auto trans can be a weak spot in these cars. So tell us what you have Manual/Auto, Turbo/Non-Turbo?
Nope same tank
Nope pop the hood, and you can always check your oil while you are there. Good habit to have anyways.
Hope that helps. No I was not trying to scare you with the tranny thing. Any questions about it please post them up.
And welcome
The silver 03 GT is gone, but a Solstice has arrived. There are three more PT's to play with though
My personal thanks to veteran and novice crewbies that have offered information and how-to's they have been instrumental in taking LiquidPT from modded car to stock to live a more quiet and sedate life.
Old 08 May 2009, 09:26 am
eklipsis's Avatar
Also the multi-function switch is a common problem
-Anthony
01_Pt_Cruiser
Old 08 May 2009, 10:11 am
I forget about that one sometimes since I don't have fog lights in my daily PT.. I don't drive my GT enough to have burned it up yet.
Its a simple fix if you do blow the switch, a couple phillips head screwdrivers, flashlight(a couple of screws are really hard to see) a $60 dollar part and about an hour if you have no clue what you are doing. Lots less if you have a clue.
Old 11 May 2009, 06:42 am
yaris's Avatar
its an manual non-turbo
Old 11 May 2009, 08:07 pm
Ignition wires. Stock ones don't last - get a good brand and put in new plugs at the same time (gap at 0.040) and you won't get a stumble or hesitation.
Old 11 May 2009, 10:32 pm
Yeah. Buy one now, and always check your fog lamps when you shut down.
Old 12 May 2009, 01:16 pm
Cool now order replacement shifter bushings from boogerracing.com
Yours will be shot and creating lots of slop in the shifter.
And yeah you will get to miss the trans craziness of the autos that 5-speed should hold together for a very long time and just be fine..
though you will need to flush at 50K or so, even though its says lifetime fluid you should know what's going on in there at its lifetime midpoint.
New PT Owner Has Questions Ineffable_Jeff Tech & Performance Forum 6 03 Aug 2008 04:15 pm
New Turbo Owner Battery Questions freakengine General Turbo Discussions 4 01 Jun 2008 09:21 pm
A couple of questions -- general detailing ?'s Cruising Mike The Detail Shop 3 16 May 2005 12:16 am
New GT Owner...A few Questions jbrown1977 General Turbo Discussions 13 18 Mar 2004 05:56 pm
Boost Controller and Gauge Questions Dalite Turbo Performance 13 14 Jul 2003 01:20 pm
