I'm in the pacific north west and I get pine needles all the time so just go with me on this. Umm check all the door jams for pine needles or other muck, I park outside year round and they get clogged up and water can run to other places if there path is blocked up. Also pop the hood and check that the cowl(the big plastic part the wipers stick out of is tight under the windshield, pushing and pulling a bit will tell you. Also look to see that its smooth across, its two pieces and if they are not installed correctly water can get in easy. Also check that it is clear of pine needles or other muck. Use towels and soak up as much as possible, if you can park it where windows are open great. When driving keep the vents open and flowing on floor setting helps lots. Sounds like a seal gone bad truthfully.. Do you have a sunroof? I know its strange they can leak and they do have drain tubes that run down the pillars up front.
The silver 03 GT is gone, but a Solstice has arrived. There are three more PT's to play with though ![]() My personal thanks to veteran and novice crewbies that have offered information and how-to's they have been instrumental in taking LiquidPT from modded car to stock to live a more quiet and sedate life. |
Hi Joile Girl and welcome back. Use a air hose and blow out all of the drain lines from the sunroof drain lines (2) and the drains under the hood left/right where rain should run out of, they are located in little wells about 1" diameter.
![]() 2008 Silver Steel Metallic, Touring, NA, Sirius; Chromed door handles; lower grille; fog light surrounds; chrome front & rear bumpers strips; Airaid air filter; Bassani duals; Modesty Cover; Autolite AP5263 Platinum Plugs (.040); Crane Plug Wires; NAPA Ceramic pads; Blane hood struts; PTeazer Gas, Brake & Foot Rest Pedals, '05 Rear Step Pad, Stainless Door Sills, Llumar tint, "A" Piller chrome; APC Strut Bar |
Thanks for all the suggestions, no sunroof though. I'm going to go lift the hood and look around. My nephew in laws thought maybe there was a cabin filter, they didn't look at my car and aren't familiar with PTs but I was kinda hoping it was that simple
I'll see what I can see. I drop it off on my way to work. I did soak up as much water as I could with towels and tried to dry it out. Tonight when I got in it after it sitting all day windows up after the carpool dropped me off it kinda smelled alittle musty
Jolie 2006 Touring Edition |
Ok, I've been out looking at everything.....could this be it??
I open the drivers door and look there is an accordiaon hose that is loose and I can see in the hole where the "plug" at the end of the hose should be and can see wiring inside there. I opened the passenger door to compare and the accordion hose on that door the plug on the end is sealed tight inside the door frame. Could rain be getting in there? Since it's where the door opens? Maybe running down and getting in that hole? What would that wiring be? I'm curious because I'm having issues once in awhile with my outside temperature reading on the gauge on the dash.....sometimes it won't read the temp, just dashes and then if it finally starts reading the number starts real low and cycles one number at a time up to what the outside temp is and gets slower and slower til it gets there. I mentioned this to the service department and they had never came across this. Now it makes me wonder if the wiring is getting wet....
If not, seal at base of windshield could be leaking... The "bellows" with wires in them isn't your problem, and overhead temp wires don't go thru door. Could also be when you had your car serviced some klutz knocked a bottle of water over and didn't say anything.... I'd say put newspaper on the floor, run a hose on base of windshield, and see when papers get wet. How is the rubber seal on the door? If rain was wind-driven, could've worked it's way in.
I'd bet a dollar to a doughnut that the bellows being loose on the drivers side is where your water leak is. The cabin air filter is an option but it is on the passenger side. Water leaks are a very uncommon happening.
As for the temperature gauge... That's not uncommon. My 06 does it every once in a while. I think there may be a computer update for this but I'm not sure. |
The wiring is for you power door locks/windows/speakers. They always get wet, fact of life since the window goes up down and water drips down. So don't panic over the door rubber yet.
The seal to be concerened about is the big rubber one that goes around the door attached to the car, its the one that keeps out the water. I second the sunroof drain lines. Please post a pic of the stuff your drivers door is missing we can compare to ours and tell if its normal or not. Sometimes things are not symetrical.
Definitely not a sunroof problem since my car doesn't have a sunroof.
It was too dark when I got up and left this morning to take any pictures but it should be a good day for them to tell where the leak is coming from. It has been pouring and storming all morning. Hail and good chance for tornados and lots more rain this afternoon. LOL welcome to the Midwest.
The plus side, we live 10 minutes from the track and try to get out on weekends as often as we can.
2001 LE, Shale Green, Aftermarket Wheels, Shorty Antenna, AirRaid Cold Air Intake, Whelen Talons (amber/white) in front windshield, Whelen Talons (amber) in rear side windows, Tomar RECT25's (amber) and Whelen Slimlighter(amber) in back window. Kenwood TK-880H 45 Watt Mobile Radio, Antenex 3db antenna w/ NMO mount. http://smg.photobucket.com/albums/v7...0PT%20Cruiser/ |
| Boiling water sound under the hood drivers side | csd | Tech & Performance Forum | 19 | 20 Aug 2011 08:12 pm |
| Some A-hole cut my top on the drivers side | MINIHEMI46 | PT Cruiser Convertible Forum | 21 | 02 Jan 2010 11:37 pm |
| water leaking | six0fourgirl | Tech & Performance Forum | 18 | 02 Oct 2008 09:51 am |
| Drivers Side Headlight | 2k1PT | Classifieds: Want To Buy | 2 | 23 Aug 2008 03:39 pm |
| Cap in drivers side fender wheel? | DannyR | General Turbo Discussions | 14 | 17 Feb 2006 02:18 pm |
