Another Radiator/Trans cooler question?
Old 17 May 2009, 09:30 am
mjb457's Avatar
Default Another Radiator/Trans cooler question?
Ok after further examination it appears that the fluid Im dripping ever so slightly onto the bottom fan cowl & battery tray is red & feels & may be trans fluid?? Its red & stays on napkin... anyway is there a trans cooler in the radiator as well as the external trans cooler under the car?? The trans fluid appears bubbly?? Im at 69200 on my 7/70 power train warranty? Covered? Im not in my 3/36 anymore.. more tips thanks MJB
Old 17 May 2009, 10:54 am
Default Re: Another Radiator/Trans cooler question?
The trans is covered by the Power Train Warranty so I'd get it to the dealer ASAP.
The trans cooler for the Non-turbo is attached to the bottom left (when under the car) side of the radiator where as the trans cooler for the Turbo models is attached to the radiator right above the inter-cooler.
Old 17 May 2009, 06:24 pm
mjb457's Avatar
Crewzin: As stated,,, is the cooler under the car? near the passenger side-from the front,,, the only cooler..or is there one alsrso in the radiator like the older cars- meaning is it seperate ,,so it cant contaiminate the trans? thanks..(its a Non turbo PT)just clarifying it,,also calling dealer in am,,thanks MJB
Old 17 May 2009, 06:35 pm
According to the manual on Non-turbo cars it's located attached to the radiator at the left side bottom.
Instructions to remove:
1.Remove the front bumper cover.
2. Loosen the hose clamps and disconnect the oil cooler hoses.
3. Remove the fasteners that attach the transaxle cooler tothe radiator.
4. Remove the oil cooler.
Picture isn't very clear, but the electrical connection to the right of the arrow is the wires for the fan motor.
Old 17 May 2009, 08:38 pm
mjb457's Avatar
OK I rechecked trans fluid when fully warm-it seems normal pink & ok,,,, anitfreeze is full...another idea --could that red spot-small drip near battery tray & fan shiels bottom be coming from power steering?? same color,,, ( my line was replaced at 18K on a recall) does it go anywhere in that area?? again thanks,,MJB
Old 17 May 2009, 08:52 pm
The recall was for the lines running from the power steering pump over to the steering gear running under the transaxle. On some cases the lines were rubbing on the transaxle and causing a leak that could cause a fire. Yes, it could be the fluid from the pump but there's no way to tell without an examination of the area. That's the best I can tell you.
Luggage Rack question and trailer hitch question Patrick_Dickey General PT Cruiser Discussions 5 26 Apr 2009 09:19 pm
PT / SRT-4 Rear Sway Bar Question Maxxam Turbo Wheels/Suspension/Handling 11 13 May 2008 02:29 pm
question about head unit upgrade Avus Sound and Security Forum 1 08 Jun 2004 06:32 pm
Inter Cooler Question stehmangarage Turbo Performance 20 02 May 2004 03:04 pm
Have a question for Andy Gorlich Capt Kidd General PT Cruiser Discussions 0 30 Mar 2004 10:18 pm
