Aligning Headlights from left to right
Old 24 May 2009, 03:36 am
Default Aligning Headlights from left to right
Is it possible? because my left headlight reaches to the right, past the right headlight and there is no light on the left side of my PT. Could this alignment be possible and if so how would i do it and if not what are some suggestions?
Old 25 May 2009, 06:22 am
Vengence's Avatar
Default Re: Aligning Headlights from left to right
I wouldnt know, my friend wants to know the same thing but nothing yet. hopefully one of the people on this forum can answer this.
My PT's-
2008 PT Cruiser LX Inferno Red
2003 PT Cruiser Base Woody Edition
Old 25 May 2009, 11:49 pm
Vengence's Avatar
align the headlights vertically (up and Down). there is a hole near the reflector or near the turning light. get a 20 torx screw driver and turn in the direction you need them aligned to or a philips head screw driver if you recently replaced them like i did and take it from there. make sure your about 20-25ft from a garage door and align them perfectly. hope this helps. if that dont fix the problem then you might have to get a whole new headlight assembly.
My PT's-
Old 14 Jun 2010, 04:41 pm
CreepyPT's Avatar
Send a message via Yahoo to CreepyPT
I would suggest getting in throught the fender well and make sure the bulb isn't loose or installed wrong. They don't "thread" in quite like a screw, but they can be put in crooked, or not completely, and the headlight will skew in the wrong direction.
Old 14 Jun 2010, 05:40 pm
This is a post from 2009, but thanks for another idea.
Horn and headlights problem ducerman Tech & Performance Forum 6 18 Dec 2007 10:24 pm
Noise in front when making left turn; not right Runkle Wheels, Tires, Suspension 2 12 Feb 2007 01:04 pm
Poping on left turn. Hotrod Wheels, Tires, Suspension 8 07 Jul 2006 11:31 am
Anyone have problems with Headlights? Ginger Tech & Performance Forum 8 01 Jun 2005 07:11 pm
