AUTOMATIC TRANS SERVICE RECOMENDATION::
Old 27 May 2009, 07:46 pm
mjb457's Avatar
Default AUTOMATIC TRANS SERVICE RECOMENDATION::
Ok My PT has 69500miles... The trans was serviced-filter changed at 32K miles.... When should this be done again? It is operating fine>> I am not looking for problems... The dealer wants to do it now... I am afraid that the tech may screw something up// thought suggestions... or is it a good idea? ( I know its been posted before-but ) Thanks MJB
Old 27 May 2009, 08:02 pm
Default Re: AUTOMATIC TRANS SERVICE RECOMENDATION::
You say it was serviced. Was the pan dropped, filter changed and only about 4 Qts added? The whole system holds about 16 Qts and needs to be flushed to change the whole thing. A lot more expensive so it's up to you. Changing it just the way your doing it (4 Qts) is better than nothing so if you don't want to put out the extra, keep up the smaller changes.
Wait for other responses to get more opinions.
Old 27 May 2009, 08:18 pm
Sounds like they dropped the pan and filled up with fluid. I would get a tranny flush - which changes all the fluid - dumping the pan only changes less than half the fluid.
I had it done at my mechanic (requires a machine to do the flush) and ran about $200.
Old 28 May 2009, 04:39 am
mjb457's Avatar
Ok,,Im still trying to find out what is recommended miles for this,,,, ??? Am I wasting $$ getting it done at 70K since it was done at 32Kmiles... Not looking for problems-just maintaining..thanks again..MJB
Old 28 May 2009, 11:33 am
mjb457's Avatar
Update----Manual says 48K under schedule B hard use-none for schedule A-which is me??no change at all...{. I just dont want to waste money in these times}}}....thanks MJB
Old 28 May 2009, 12:52 pm
Seeing that you have this question in your mind, I would recommend that you go ahead and do a flush & drain. Yes, I know it is expensive, but it would give you peace of mind.
That said, I just looked in my 2008 Service Manual Schedule "A" which I feel I belong and it says, "No change necessary". There is NO LISTING for Schedule A, but it states "if any of the 10 conditions listed apply to you, it is a Schedule B".
Conditions are:
Day & night temperatures are below 32 F.
Stop and go driving.
Extensive engine idling.
Driving in dusty conditions
Short trips of less than 10 miles.
More than 50% of driving is at sustained high speeds during hot weather, above 90F.
Trailer towing.
Taxi, police or delivery service (commercial service ).
Off-road or desert operation.
If equipped for and operation with E-85 (ethanol) fuel.
Old 02 Jun 2009, 09:48 am
Travis2k7's Avatar
[/B][/COLOR]
That's kinda what I am looking for as well... bought my auto non-turbo PT 3 months ago at 45k and just had my 48k service... (synthetic oil and rotation)
As I recall the owner's manual says tranny service at 60k but I may be mistaken. I've been reading on these forums that most people are saying 50k so it has me thinking about getting it serviced now.
I have no idea of the prior maintenance on the vehicle so peace of mind would probably do me a lot of good. The car has been flawless over the last 3500 miles but still....
2006 Limited, Auto, 100k miles
Old 02 Jun 2009, 12:55 pm
Every 30k alternate between a drain and fill and a full tranny flush.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
2003 Auto Trans - Fine one day, bad the next??? jrrudd7 General PT Cruiser Discussions 3 04 Nov 2008 03:12 pm
Automatic trans sensor Dvox Tech & Performance Forum 1 25 Apr 2008 03:48 pm
60K service on 2001 PT, S. California gychang General PT Cruiser Discussions 3 09 Jul 2007 03:41 pm
GT with automatic trans and gas mileage coopj40 General Turbo Discussions 10 22 Apr 2005 04:10 pm
30,000 Mile Service $ Yikes!! BB General PT Cruiser Discussions 8 23 Jun 2004 08:02 pm
