AC Only Blows Cold While Moving....
Like Tree5Likes
Old 31 May 2009, 01:13 pm
Default AC Only Blows Cold While Moving....
Just had the refrigerant checked - was a pound down. The tech said the compressor was going. $1300 parts/labor which seems like BS to me.
Hard to believe on a car w/ 40,000 miles. Why would it only blow cold while the vehicle is moving? Blows cold and strong while moving.
Old 31 May 2009, 02:13 pm
Default Re: AC Only Blows Cold While Moving....
Cooling fan is not working. Excess pressure has caused venting. Very common problem.
Old 31 May 2009, 04:01 pm
prettybluewoody's Avatar
I'll second Slarty and the fan, 'cause that's what happened with mine!
Cool air coming through while you're moving, right? Then nothing while you're stopped? Yep, it's the fan.
prettybluewoody
2003 Limited Edition PT Cruiser:
Electric blue with Moss Motors 2-tone ABS woody panels, assorted woody touches here and there and a custom electric blue keyfob
Old 31 May 2009, 04:03 pm
I should have added: the cool air comes through while in motion BECAUSE of the motion: the air you're driving into is the only thing cooling the motor. While stopped, there's no air being forced over it (which is what the fan is supposed to do!), and that's why no ac unless the car is moving.
prettybluewoody
Old 31 May 2009, 06:15 pm
Yep, it's the fan. Had the same problem, changed the fan, everything was fine again.
Old 01 Jun 2009, 07:51 pm
Could the fan work intermittently? Drove 200 miles today and it seemed ok. Still blew cold air when the car was at a stop - colder rf course when the compressor was cycled on.
Old 01 Jun 2009, 09:27 pm
Yes... but not the way you think. If the engine gets hot enough top turn on the fan then while you are at idle the fan will run on low speed till it cools off then turns off. So it could appear that it works intermittantly. That along with the freon being low....
Old 02 Jun 2009, 06:18 pm
So what is the fix for the fan not working???? I'm having somewhat of a similar problem except my AC totally quit working.....with smoke and everything. If I look at the compressor there is no belt going around it. But even with that the car is over heating because the fan is not working. So....what is the fix for the fan?????
Please, please help!!!! Thanks!
Old 02 Jun 2009, 06:34 pm
The fan not working is probably a burnt out fan motor. You can buy just the motor or the whole shroud with fan and motor together.
You big problem is that if there's no belt on the compressor, that's the serpentine belt that drives everything except the alternator. You shouldn't be able to drive at all.
Old 02 Jun 2009, 08:55 pm
Well I was able to get under it and you are correct that there actually is a belt on there So....I was looking at the fan shroud and I have a big question....... if I undo the bolts, will the whole shroud just slide out without taking the radiator hoses off? If it does then I could change the fan motor???
EDIT: I looked up online for fans - autozone and advanced auto parts have several different fan sizes, 9", 10" and 12" but I went out and meassured mine and it was 16"??
I believe this is the correct one (16").....
FAN ELECT REVERSE by Mr. Gasket - Part 17360081 - Advance Auto Parts
Stock Airbox vs. Cold Air Intake/Cone filters Gold GT Turbo Performance 7 16 Jul 2007 01:10 am
PTs and the "cold" yukonsly Canada PT Forum 6 30 Jan 2004 04:58 pm
Cold Cold Crazy PianT General PT Cruiser Discussions 13 21 Jan 2004 11:35 pm
Real cold air intake Airbillster Tech & Performance Forum 5 02 Sep 2003 02:26 am
A TRUE cold air intake Airbillster Turbo Performance 7 14 Aug 2003 01:19 pm
