pt cruiser 03 air conditoner
Old 06 Jun 2009, 06:31 pm
Default pt cruiser 03 air conditoner
my pt cruiser 2003 air conditoner did not work since 3 month i dont knaw whay
thers no coold air but when i put it to hoot air its ok
its lok like electrc propplem
i dont knaw wher the a/c fuze
if any one have photo fore the fuze box ples post it her
Old 06 Jun 2009, 06:47 pm
Default Re: pt cruiser 03 air conditoner
ashehri,
Just because you have hot air doesn't mean there's an electrical problem. Have you checked the freon/R143 level for proper balance? That's the first thing that goes wrong. A low level will shut the compressor off until it's refilled.
Old 07 Jun 2009, 12:57 am
how i can chak the freon/R143 level
when i went to the mecanec he told me the freon/R143 level is ok
so wher is the propplem
Old 07 Jun 2009, 06:22 am
So, the mechanic said the levels are OK? Didn't he have any idea why your not getting cold air? Was the compressor cycling on and off like it's supposed to?
If you want to check, the fuse box in the engine compartment has the fuse for the air-conditioning. It's the No#11 fuse.
Old 07 Jun 2009, 04:57 pm
its rely strang the fuze is ok but i think as u sed the feron level its the propplem
naw how i knaw that
my mechance told me ther is feron inside
but until naw ther is not cooling
Old 07 Jun 2009, 05:01 pm
He told you there is freon inside but did he check it with guages to make sure the high and low sides have the correct amount? If not, you'll have to find a different place to have it checked out for the proper levels.
Old 07 Jun 2009, 06:09 pm
ok i will go to othr on
but i dont naw the correct amount if u naw ples tel me
Old 07 Jun 2009, 06:12 pm
No, I don't know the correct amount but any competent mechanic with a set of gauges should know. I take it your not in the U.S. so is there any place that deals in air-conditioning where you live?
Old 07 Jun 2009, 06:29 pm
am in saudi arabia and moste care her coming from japan
no on her naw how to fex this care becuze the japans car is very sampel to fex
but this on is not
all the mechanec told me u need to have other car this on is not good
evry 6 monthe u need to fex the a/c
Old 07 Jun 2009, 06:36 pm
He's not telling you the truth. I've had my PT for 8 1/2 years and have only had 1 problem with the A/C and that was the pressure switch on top of the accumulator which went bad and I was getting too cold, in fact it was freezing up because of the bad switch.
If it's fixed right by a competent mechanic and the proper tools/guages then the A/C should work for years without a problem unless one of the parts break or wear out but that could happen to any car.
2004 Chrysler PT Dream Cruiser Series 3 skylight PT Cruiser News and Rumors 10 18 Jun 2009 08:57 am
Exterior Mod List slayerdarkcross Exterior Accessories Forum 8 22 Jul 2008 03:54 pm
2006 PT Street Cruiser Route 66 Edition skylight PT Cruiser News and Rumors 35 17 Nov 2007 02:39 pm
2006 PT Cruiser Pics and New Specs skylight PT Cruiser News and Rumors 14 13 Nov 2005 08:46 pm
New 2005 Convertible PT Dream Cruiser skylight PT Cruiser News and Rumors 4 11 Jan 2005 06:12 pm
