Have been having overheating problems so Hubby removed the thermostat tonight. Thinking it was sticking. I was thinking it was the rad. fan so Hub being the non mechanic that he is took the hi speed rad fan relay fuse out of it's slot and tried to run a wire from it to the pos on the battery to see if the fan would kick on. No fan and now when I try to start the car I get all the lights bells and dings on the dash but no starter trying at all. As if it isn't even hooked up. Any suggestions? I am just sick over this. I need the darn car to go to work. It has been nothing but problems since purchase a year ago. It is a 2002 and the longer I own it the more I hate it.
Sorry you hate your PT so much. Your at a site asking for help with thousands of satisfied owners.
On to your problem. Below is the fuse box in the engine compartment. Your hubby already knows all about that. All the relays in the corner of the box, including the high speed relay that hubby ran the wire too are all the same. They can be interchanged. The horn relay is the easiest to swap around. First try the horn relay in the ASD (E) slot and if that doesn't start the car, try the horn relay in the Starter Relay (B) slot. But first hit the horn to make sure that relay (A) is good.
Tried that and it didn't work. It's the strangest thing. Could this be totally unrelated to what he did? You know how when it is the battery you get the clicking? I don't get that, I get NOTHING from the starter. When the starter goes, doesn't it sort of try to start before it goes completely?
I bought this car in August last year and had to put a new engine in it in Dec. Since that time I have also had the A/C repaired twice and it is out again. I have since quit using that mechanic because I think he saw me as his payday princess. I would really like to raise the radiator cap and drive a new one underneath it, but can't afford to do that right now. Thanks for your help! |
Just thought of something else--it's as if I am not pushing the clutch in when I try to start it. Could it have something to do with that. I just went out and tried to start it without pushing in the clutch and it does the exact same thing so there must be a switch that has gone bad? And if that is it, is it easily repaired? or can it be bypassed somehow?
| Starting problem | Elrodion | Tech & Performance Forum | 0 | 18 May 2009 07:49 am |
| 07 Touring - Intermittent Starting Problem | DravenGSX | Tech & Performance Forum | 8 | 19 Mar 2009 05:58 am |
| Problem Starting 02 PT Cruiser | DavidH | General PT Cruiser Discussions | 6 | 20 Feb 2009 06:13 pm |
| starting up problem | packrat007 | Tech & Performance Forum | 11 | 15 Aug 2008 04:38 am |
| starting problem | skinnyp | Tech & Performance Forum | 6 | 28 Apr 2008 06:57 pm |
