part removal..
Old 23 Jun 2009, 09:49 pm
superpug666's Avatar
Default part removal..
Hey, just wondering how to remove the fenderwells?? (the plastic things)
thanks a lot!
I drive an hybrid, it burns both gas and rubber!!!!!
To hell with all religions!
Yes my baby is stock, for now!
Old 27 Jun 2009, 10:48 pm
Location: Belleuve, WA from Los Angeles - Road Rage specialist
Default Re: part removal..
Umm why?
The silver 03 GT is gone, but a Solstice has arrived. There are three more PT's to play with though
My personal thanks to veteran and novice crewbies that have offered information and how-to's they have been instrumental in taking LiquidPT from modded car to stock to live a more quiet and sedate life.
Old 28 Jun 2009, 05:19 am
Originally Posted by PT_Cuda View Post
Umm why?
cuz to see if its the valve cover gasket leaking......have a small oil leak on the passenger side.....
Old 28 Jun 2009, 08:31 am
Ok you didn't make clear which one you wanted to pull so the why answered that question.
Jack up car, remove wheel.
3 screws at the lip of the fender 7-8?mm
1 screw at the underside lip of the facia - bumper side
1 pop screw at the back of lower splash shield
4? screws at the top of the inner splash shield
1 pop screw that holds the inner to the fender liner
All 13mm or 10mm
The pop screws may or may not be usable after you pull them so electrical tape is your friend for helping to hold them together if they get messed up.
Wiggle the inner out and you will see the lower motor mount the belts and a few other things..
Hope that helps
Old 28 Jun 2009, 05:27 pm
All 13mm or 10mm
Hope that helps
as soon as i can ill try it, but sure looks good with so much dtails! thanks ever so much!
Need Help With OEM part number csd PT Cruiser Convertible Forum 8 05 Nov 2011 10:21 pm
Guide to Spray Paint your Center Dash Bezel Candyman The Detail Shop 1 28 May 2009 07:30 am
Cylinder head OEM part number ? csd Tech & Performance Forum 2 27 Aug 2007 07:57 pm
New Brakes... matt87951 Tech & Performance Forum 26 27 Apr 2005 02:38 pm
Mopar Warranty & Stage Kit Part Numbers skylight Stage Turbo Kits 35 08 Feb 2004 12:23 pm
