Downshift problem after changing fluid and filter.
Old 24 Jun 2009, 06:16 am
Default Downshift problem after changing fluid and filter.
What can be done to correct the hard downshift bump from 2-1 when coming to a stop? Any help would be greatly appreciated.
Old 24 Jun 2009, 08:12 am
Default Re: Downshift problem after changing fluid and filter.
Welcome.
Was it refilled with ATF + 4? Enough fluid put in?
Old 24 Jun 2009, 11:08 am
Yes ATF-4 and filled to full hot mark after it reached temperature.Then I went from Park to 1 slowly and back several times.I took it for a ride and the 2-1 downshift problem started.I read where this may be a air in the system problem.Im going to try and go thru the gears again slowly 10 or 12 times and see if this helps?
Old 24 Jun 2009, 07:09 pm
I'm far from an expert, but air would do it. I had a problem once with wife's car where it would race in idle after a turn, then slam into gear after, and ended up being a crack in a tube that would suck air in a turn, then when you leveled out & it got fluid it would slam.
Good luck & post back.
Changing Transmission Fluid garyerrol Tech & Performance Forum 10 30 Jan 2009 05:57 pm
Methanol Wiper Fluid Splash, Am I Safe? TVarmy General PT Cruiser Discussions 2 10 Dec 2008 09:59 am
