HELP!!! power steering and ac went out at the same time
Old 04 Jul 2009, 07:26 pm
Unhappy HELP!!! power steering and ac went out at the same time
I went to the dentist yesterday morning and everything was ok. I drive a 05 touring editon. Well later that evening I started up my Princess mobile and heard just a small knock. I did not think anything of since I was standing on something outside and thought it was that. Anyway, I tried to back it up that was fine. When I went to turn it was so hard. I know my power steering is out. My ac was blowing out cold air at first but then it was getting warm. Now all of this happened at the same time. Does anyone have an idea of what it could be?
Old 04 Jul 2009, 08:03 pm
Default Re: HELP!!! power steering and ac went out at the same time
Sounds like you might have blown the serpentine belt.
From PT Do-It-Yourself.net:
The serpentine belt drives the power steering pump and A/C compressor. The maintenance schedule is outlined in your owners' manual. Inspect and adjust (if necessary) the power steering pump and A/C compressor drive belt tension at 30K, 45K, 60K, 75K, 90K and 105K according to schedule B. We recommend that that you have a service manual on hand if you intend to replace any of drive belts.
The accessory drive consists of two Poly-V type drive belts. One belt drives the generator, and the other drives the power steering pump and A/C compressor (if equipped). The power steering and A/C belt is tensioned by an automatically controlled belt tensioner. (The tensioner can be irrevocably damaged if you adjust it incorrectly.) The generator belt is manually tensioned using an adjusting bolt and a locking nut.
Old 07 Jul 2009, 04:45 pm
oldretiredfred's Avatar
It has to be the serpentine belt
The Original - The 1939 Plymouth
Retired in sunny Florida
2007 Pt Cruiser Sedan
Touring Edition
Bright Silver Metallic
Old 07 Jul 2009, 06:46 pm
Yes, it was. Not a very easy job but was made alot easier with y'alls help. I did another post. There was a ground quirrel in the belt. Yes and that sucked. YUCK!!
Power Steering Problem - Funny but True... sifu_scott General PT Cruiser Discussions 17 19 Mar 2011 10:24 pm
Power Steering Pump Chrysler1924 Tech & Performance Forum 7 06 Aug 2010 02:51 pm
power steering problems bluebeard Tech & Performance Forum 1 06 May 2009 07:07 am
Power steering whine problem identified sawdust123 General Turbo Discussions 5 10 Dec 2008 07:24 pm
ATF + 4 or 5 for power steering? quicksilverdon General PT Cruiser Discussions 2 21 Feb 2005 05:00 pm
