New Guy from New Jersey.
Old 05 Jul 2009, 02:13 pm
Default New Guy from New Jersey.
Hey guys and girls.
My name is Dan, And my brother just gave me a 03 PT. Its in pretty rough shape, on the body. The motor, trans, and interior are in perfect shape. It has 82,xxx miles on it. He gave it to me for free, hes moving to Florida and didnt wanna drive it down there.
So my plans are to get it back in original condition which will require new fenders, front bumper, radiator supports, new bushings (being replace with polyurethane), a new tie rod end, some body work, and paint. Im goint to paint it black and keep some chrome (door handles, rims, and exhaust tips). Im also going to put a aFe Intake, Flowmaster exhaust, and a Jet Stage 2 chip. All in all this is going to be my daily driver, my toy is my 97 Ford Ranger. Of which I've done massive amounts of work on. Here is the only pic of the car I found (currently in a shop getting the tie rod done) and a couple of my truck.
^Thats my brother in the pic.
So are there any little bugs or anything I should check before putting the car back on the road?
Old 05 Jul 2009, 03:12 pm
Default Re: New Guy from New Jersey.
HEY !!! new guy welcome , if your having to replace the front bumper check out one of mine and if it looks like something you might like call me.or if its just a used factory bumper you want I may be able to help you out with that too.my name is Ray and my company is called Pteazer you can find all my contact info there on my sight. You must be a good guy for your bro to give that ride enjoy it.Cheers Ray Newton Pteazer.
Old 05 Jul 2009, 04:22 pm
Welcome to the forum Dan. The only thing to warn you about is that we recommend to all owners to change the timing belt, water pump, tensioner and drive belts somewhere around 100,000 miles and the cost is anywhere fromm $800 - $1200 depending on where you take it for service. Also, check with your brother and see if he's had the transaxle flushed and when. The tranny is a weak point in the drivetrain and we recommend (there's that word again) a flush no later than 50,000 miles and again about the same time as the timing belt is due.
Good luck with yours. Plenty of knowledgeable and friendly people here to talk and answer questions.
Old 05 Jul 2009, 08:35 pm
NVRDONE, Welcome to the Forum. IMHO my suggestion is to forget the Jet Chip and use that money for another MOD. You are only going to get so many MPG and no more, no matter what you do to it.
Old 05 Jul 2009, 08:41 pm
Well Since I now have two vehicles I will be doing most of the work myself so it would cost me parts and beer, lol. It dose have (From OCT-08) a fresh timing belt, tensioner, water pump, radiator, hoses, IAC valve, MAP/BARO Sensor, and IAT Sensor. From what he told me the stop bolt on the throttle body was messed with and I have to get another one on there, Is this something I can do with one from a junkyard?
Right now it blew a tie rod, the cause of which, I think, is that he never replace the A frame bushing. Depending on the condition of said part Im either going to replace it completely or replace with polyurethane bushings. Also I will be replacing the Drive belt and the tensioner. Is the transaxle fluid change something I can do? And do you reccommend Synthetic over Dino oil at all?
Im not really looking for MPG's my truck gets around 30mpg (highway), What Im looking for is throttle response and a few more horses. Pretty much a nice cruiser. I Auto-X my truck so it has a pretty rough ride due to the mods I've done on the suspension.
Old 05 Jul 2009, 09:03 pm
Not sure about the stop bolt on the throttle body. I would guess if you can find it somewhere it should work on yours.
On the tranny fluid change. It's messy job as there's no drain plug. You need to loosen all the bolts and let the pan drop on one side and try and catch all the fluid. You only change about 4 qts that way out of about 16 for a full flush but the flush can only be done by a machine at a shop.
It's up to you if you want to switch to synthetic but you'd have to do the whole flush if your going to change so your talking somewhere in the neighborhood of $200 for a synthetic flush and change against $100-$125 for dyno oil flush.
Old 05 Jul 2009, 09:21 pm
Okay sounds good. Now a few more questions. Us Ford guys, use Autolite products in our ignition. What brand is touted for these PT's?
And is there a preferred brand of Motor Oil and Trans Fluid above all?
Or should I stick to Mopar stuff?
Thanks a bunch for answering my questions and for the welcome!!
Old 05 Jul 2009, 09:37 pm
Any brand of motor oil will do. We only recommend synthetic for the turbo's, but a lot of owners, including myself, are using synthetic in the non-turbo also.
As far as the tranny (transzlxe) goes, Chrysler says to ONLY use ATF+4 (synthetic ATF+5).
This is a little old and talks about ATF+3 but good info:
Changing and flushing automatic transmission fluid
Old 05 Jul 2009, 10:04 pm
Okay, sounds good. As soon as the car hits my driveway I will be posting up a build thread. Im looking forward to posting around here and eventually contributing to this site.
Old 06 Jul 2009, 08:02 pm
Welcome.
Where 'bouts in Joisey?
Nice of your brother...
To the list I'd add plugs & wires - there's a guide here on how to change them.
Don't buy stock wires, they are crap - Cranes (if you can find them) - magnecore,... the Champions are fine - gap at 0.040.
YOUNG'S JERSEY DAIRY PT CRUISER CAR SHOW 17-19 JULY 2009 PTSHARK PT Cruiser Events 0 04 Jan 2009 11:23 am
Hi.....Anyone in Jersey? Cathy06PT Northeast PT Forum 12 02 Jun 2008 04:32 pm
Young's Jersey Dairy PT Cruiser Car Show LOINFISH PT Cruiser Events 15 17 Feb 2008 12:11 pm
headlight flames for New Jersey gonzomania General PT Cruiser Discussions 7 09 Mar 2004 08:47 pm
If you live in New Jersey Please read Grouch General PT Cruiser Discussions 1 22 Apr 2003 05:31 pm
