Loss of cool air when gently accelerating
Old 07 Jul 2009, 12:07 am
Default Loss of cool air when gently accelerating
My 2001 PT Cruiser Limited temporarily stops blowing cold air from the air conditioner when the engine is under strain, not just the heavy strain that normally temporarily cuts off the cold air.
Any advice or suggestions are greatly appreciated. Thanks!
Old 07 Jul 2009, 06:12 am
Default Re: Loss of cool air when gently accelerating
It's the PCM (computer) that controls this action by turning off the compressor to give you more power (you probably knew that) so the problem almost certainly is with the PCM. Have you tried resetting the computer by pulling off the negative battery cable? This clears up a lot of problems, it's like rebooting your home PC.
Old 07 Jul 2009, 06:52 am
Welcome.
Also check that the engine fan comes on when you turn on the A/C.
How Much Horsepower Loss.... BB Turbo Performance 12 30 Jul 2008 08:55 am
Cool is not as easy as it seems skylight PT Cruiser News and Rumors 5 08 Feb 2008 09:07 pm
turbo cool down turbomangt General Turbo Discussions 12 08 Jun 2003 12:03 am
