Damn NJ Inspection Stations!!!
  #11 (permalink)
Old 12 Jul 2009, 09:18 pm
Default Re: Damn NJ Inspection Stations!!!
Well here in PA we reject the inspection meaning there is a no charge retest with in 30 days of the first try. I don't write the rules I just have to follow them.
  #12 (permalink)
Old 16 Jul 2009, 09:02 am
Taggert_LOA's Avatar
Send a message via AIM to Taggert_LOA
Originally Posted by CREWZIN View Post
HI. Not sure what you mean but if you take the negative battery cable off for a couple minutes, it clears the computer of the code you have and all the other codes that might be stored.
which they will immediately fail you for here as they will see the battery was disconnected within the last 50 starts.
"Every civilization finds it necessary to negotiate comprimises with it's own Values"
  #13 (permalink)
Old 16 Jul 2009, 09:04 am
How would that work exactly? We have a fault like this: P1684 - The battery has been disconnected within the last 50 starts. But 50 starts could be 2 months ago, or more, depending on how often the car is used, so how could you tell if it was "just" cleared or 2 months ago?
What happens if you just put a new battery in, or had some service work that required that the battery be disconnected. Half the procedures in the Haynes and Chilton manual start off with "disconnect the negative battery cable".
That's a stupid thing to do, fail someone for the battery being disconnected.
So, I just spent $1000 to have the timing belt replaced before anything goes wrong (preventative maintenance) and then I take it in for inspection and you fail me because the battery was disconnected?
Welcome to NJ.
  #14 (permalink)
Old 16 Jul 2009, 09:32 am
Originally Posted by Taggert_LOA View Post
Welcome to NJ.
Remind me to go thru PA on the way to the Big Apple next time. Probably save me a few bucks taking 95 anyway instead of the wallet robbing NJ Turnpike.
  #15 (permalink)
Old 16 Jul 2009, 12:03 pm
Travis2k7's Avatar
Georgia, the land of no inspections.
2006 Limited, Auto, 90k miles
  #16 (permalink)
Old 18 Jul 2009, 11:41 am
Here in England they call it MOT every year. My PT failed this year because the yellow turn bulbs were not yellow enough. They replaced them with fresh bulbs for only £12.00 each installed. Bend over and pay or park, Govt needs money--andy
http://
Alberta out-of-province inspection SauerJen20 Tech & Performance Forum 4 19 Mar 2008 12:06 pm
DAMN THEIVES PT Chix General PT Cruiser Discussions 5 11 Mar 2006 08:44 am
State Inspection with Stage 1 in Texas JohnM Stage Turbo Kits 9 04 Jun 2004 11:15 am
Emmisions inspection w/Stage 1 Gear_Head Turbo Performance 6 05 Oct 2003 04:08 am
Oil filter inspection GTSteve Tech & Performance Forum 1 02 Oct 2003 02:55 am
