Valves and Pistons
Old 21 Jul 2009, 08:40 am
Send a message via AIM to fljohnboy
Default Valves and Pistons
I read this where someone asked this question and someone answered. I will paste below. After reading that would you think that's a correct answer?
QUESTION:
I got a question for thoose who have gotten there timing belt changed. Are the pistons far enough away from the valves to not hit in a 2002 Pt cruiser.
ANSWER:
The 2.4 Liter used in the PT Cruiser is a non interference engine which means if it breaks it won't damage the engine.
Old 21 Jul 2009, 09:56 am
Default Re: Valves and Pistons
The valves won't hit the pistons, but the valves can hit each other....
Old 21 Jul 2009, 12:35 pm
mopar_man's Avatar
Yep. So it's actually still an interference engine but in a different way. A friend of mine runs a parts store here and in the 100's of timing belts he's sold for the 2.4, mine and two others were the only ones that he has seen that didn't connect.
1973 Barracuda
340/auto
Modifications: Too many.
2002 PT Cruiser
N/A 2.4L/5-speed
1989 Caprice Wagon
307/auto
loose timing belt and gears not moving - urgently need help pls. lanies_ptcruiser02 Tech & Performance Forum 12 12 Aug 2008 05:36 am
We're 16 hours into the engine and it's not out jennylyn General PT Cruiser Discussions 3 18 Mar 2008 04:51 pm
