VIN G ??????????
Old 31 Jul 2009, 11:05 pm
Send a message via AIM to fljohnboy
Default VIN G ??????????
When looking for parts such as spark plugs like at Autozone it specifies a Vin G. My car is a 2005 GT and no G's in my Vin number. Can someone explain this Vin stuff?
Old 01 Aug 2009, 06:51 am
Default Re: VIN G ??????????
If you think that's confusing. This is from an ad for a water pump gasket:
* 2001-2006: Limited; 4Cyl 2.4L GAS, FI, VIN "B";
* 2001-2006: Touring; 4Cyl 2.4L GAS, FI, VIN "B";
* 2001-2006: Base; 4Cyl 2.4L GAS, FI, VIN "B";
* 2001-2005: Classic; 4Cyl 2.4L GAS, FI, VIN "B";
* 2002-2002: Dream; 4Cyl 2.4L GAS, FI, VIN "B";
* 2003-2006: GT; 4Cyl 2.4L GAS, FI, Turbocharged, VIN "G";
* 2004-2004: Limited; 4Cyl 2.4L GAS, FI, Turbocharged, VIN "8";
* 2004-2004: Touring; 4Cyl 2.4L GAS, FI, Turbocharged, VIN "8";
* 2005-2005: Dream Cruiser; 4Cyl 2.4L GAS, FI, Turbocharged, VIN "G";
* 2005-2005: Street Cruiser; 4Cyl 2.4L GAS, FI, Turbocharged, VIN "G";
* 2006-2006: Base; 4Cyl 2.4L GAS, FI, VIN "X";
* 2006-2006: GT; 4Cyl 2.4L GAS, FI, Turbocharged, VIN "S";
* 2006-2006: Limited; 4Cyl 2.4L GAS, FI, Turbocharged, VIN "E";
* 2006-2006: Street Cruiser; 4Cyl 2.4L GAS, FI, VIN "B";
* 2006-2006: Touring; 4Cyl 2.4L GAS, FI, Turbocharged, VIN "E";
* 2006-2006: Touring; 4Cyl 2.4L GAS, FI, VIN "X";
I found out that the VIN "?" is the 8th position on your VIN breakout. I'll have a couple breakouts in a second.
Old 01 Aug 2009, 07:15 am
Travis2k7's Avatar
As I recall the letter is the 8th spot of your VIN which I'm guessing identifies the engine type or something to that effect.
Mine = 3A8FY68BXXXXXXXXX.
2006 Limited, Auto, 90k miles
Old 01 Aug 2009, 07:42 am
Yes, 8th position is the engine type......
Old 01 Aug 2009, 09:13 am
ok, my car is a 2005 GT Turbo vert with a "S" in position 8. Recently put new plugs in, Champion 7570's. I was on the sparkplugs.com site and it doesn't list any Champions for the "S". Reading the threads and posts here some say not to use the 7570's in a turbo engine and some say yay. OK sparkplug Guru's lay it on me.
Old 01 Aug 2009, 09:30 am
The consensus is to NOT use the platinum plugs in the Turbo. I believe it's because the extreme heat that the turbo puts out. Stick with Champion (or other brands) copper plugs and gap them around .032in. Don't forget to use anti-seize on the plug threads and die-lectric grease on both end of the plug wires.
