Power steering pump question
Old 05 Aug 2009, 08:02 pm
Default Power steering pump question
My wife let the power steering fluid get low in her PT. I refilled it and it now has some noise on start up which disappears after running a while. I thought it was just some air that would work itself out but it's been a few days and it's still doing it. Is there a bleeding procedure needed? On checking around I heard that Chrysler was saying that pump noise was common but that's only one input. Any help would be appreciated.
Dick
Old 05 Aug 2009, 08:17 pm
Default Re: Power steering pump question
Dick,
What did you fill the power steering unit with? There's a TSB (#1900701) from Chrysler that specifies only one particular type of fluid to use.
Old 05 Aug 2009, 09:54 pm
Sharkstooth's Avatar
Can you see if the pump is leaking at all because it could have a bad bearing causing it to whine.
Old 06 Aug 2009, 05:03 pm
ADR's Avatar
ADR ADR is offline
Dick
I might hear the same "noise", but the fluid level seems fine.
The power steering "noise" tends to whine during cold nights, right after start-up. Even if you don't turn the wheel, it will intermitently whine. More so, if you turn the wheel.
After it warms up to operating temp, it's almost unnoticeable.
I wonder if we have the same issue??
Old 08 Aug 2009, 12:39 pm
Perhaps try putting in some of that thick power steering whine-stopping liquid? I bought some in a white container and used it on previous cars (pt hasn't needed it yet), and it helps really well.
Silver 2002 pt cruiser touring edition, auto, dark ass tint, 89k miles... shift burp mod, SRI
2005 civic ex special edition, 5spd, fully loaded, 40k miles
I have a wide-band o2 sensor for sale!! PM ME!!
Power Steering Pump Chrysler1924 Tech & Performance Forum 7 06 Aug 2010 02:51 pm
Cost to replace power steering pump? djfox1 General Turbo Discussions 4 24 May 2009 07:42 am
Power Steering Pump & Serpentine Belt? ChicagoPT Tech & Performance Forum 4 24 Apr 2009 10:51 pm
A/C, power steering question gmartinz Tech & Performance Forum 2 20 Jun 2007 09:29 pm
Power steering pump pulley ? JGN General PT Cruiser Discussions 10 22 Aug 2004 07:49 pm
