High Side Pressure switch
Old 07 Aug 2009, 07:21 pm
Thumbs down High Side Pressure switch
How can I check the High Side Pressure Switch on the AC. Fan does not come on when AC is on. Fan works when engine temp rises.
Old 07 Aug 2009, 08:39 pm
Default Re: High Side Pressure switch
What you just described is not the switch but the low speed part of the fan. It should come on with the A/C.
Old 07 Aug 2009, 10:31 pm
Thumbs down Re: High Side Pressure switch
is that one of the relays that is under the hood that could be bad? I notice there are two in the fuse panel under the hood.
Old 08 Aug 2009, 05:49 am
Yes, The high speed relay can be swapped with the horn relay to see if it's working but the low speed is a separate switch. There might be a way of testing it but I don't know how.
Old 08 Aug 2009, 08:24 am
Thanks for you help I will test it out today.
A/C Low Pressure Switch, where is it? KJEandLWE Tech & Performance Forum 30 23 Jul 2011 03:59 pm
A/C Low pressure switch rhohmann General PT Cruiser Discussions 3 18 Jun 2009 11:50 am
check eng light reaper121 Tech & Performance Forum 12 29 Oct 2008 02:23 pm
