Which Motor Oil
Old 20 Aug 2009, 11:46 am
Default Which Motor Oil
Hi,
Which motor oil shall i use in my PT 02 52k??
Old 20 Aug 2009, 01:07 pm
Default Re: Which Motor Oil
Welcome to the Forum!!! Most of us use Mobil 1synthenic for the Oil, 5,000 between changes.
Old 20 Aug 2009, 02:38 pm
thanks, i've seen a few different types 0w/40, 15w/50, 5w/30
which would be best and what are the differences for my PT?
thanks soo much
Old 20 Aug 2009, 02:46 pm
mopar_man's Avatar
I use 5w30 Amsoil in mine. Just about any quality synthetic is better than regular oil. As for the weight, there's been discussions about that but I stick with what is recommended on the cap or slightly lighter for the winters.
1973 Barracuda
340/auto
Modifications: Too many.
2002 PT Cruiser
N/A 2.4L/5-speed
1989 Caprice Wagon
307/auto
Old 20 Aug 2009, 03:56 pm
thanks soo much
It all depends where in the US you live. Can't help as your profle isn't filled out. Go to CP in the upper left corner and fill if you wish.
Old 20 Aug 2009, 04:17 pm
Travis2k7's Avatar
Hi,
In my PT 06 52k I use Mobil 1 5W/30.
2006 Limited, Auto, 100k miles
Old 20 Aug 2009, 04:34 pm
wheelgarage's Avatar
Mobile 1 Full Syn - 5/30
2005 Touring Black - Automagic....California Smog Legal
H&R Cup Kit | TSW Sakata 18x8 35ET | Nankang NS-II 235/40/18 | SPC front alignment cam - rear shim | Master Pro Rotors | Master Pro Ceramic F/R pads | Rebuilt Cylinder Head - Safety Valves and Guides | Felpro Head Gasket and upper rebuild kit | Fail-safe 195 degree thermostat | Mopar Waterpump...lol | 3rd radiator fan motor | Gates timing belt kit | WIX filters (oil, transmission) | Mobile 1 5w30 | Mopar ATF4 | Redline Water Wetter | K&N Drop-In | 4th Drive side Axle | Energy Suspension Torque Mounts | 3rd set of Torque Mounts...
Old 20 Aug 2009, 05:12 pm
2001 99,000 Mobil 1 5W30. Mobil M1-102 filters also. 5k between changes.
Old 20 Aug 2009, 07:25 pm
5W30 is the Chrysler recomended blend. Way back in the early 2000's Chrysler came out with a TSB spelling out their recomendations for the vehicles in production then. If you use a bled that has a heaver viscosity you may set a Check Engine Light (CEL). You can look up this TSB on the WWW to see the entire discussion.
Personally, I prefer synthetic over dino--less chance of sludge build up and I feel the performance factors justify the small additional cost for the longer period between oil changes--I also go at the 5000 mile point or yearly--wich ever come first.
My ride has 3120 miles and is 14 months old. I am on my second change based on time on earth and the stop and go driving I do.
Old 20 Aug 2009, 08:54 pm
yaris's Avatar
2006 pt with 58000km, I use castrol syntec 5w30 and NAPA filters every 10000km
