Inside door handle won't work 2006 PT
Old 21 Aug 2009, 02:41 pm
Unhappy Inside door handle won't work 2006 PT
My wife just closed the front door on the seat belt and now the door handle won't work from the inside. The outer handle/button will open the door. When you pull on the inside handle, nothing happens, it feels like it's not connected to anything. Help!
Old 21 Aug 2009, 02:52 pm
Send a message via AIM to slayerdarkcross Send a message via MSN to slayerdarkcross
Default Re: Inside door handle won't work 2006 PT
See that white piece above the red wire. The arm may have popped out. It clips into place so I would check to see if that's it.
Old 21 Aug 2009, 04:29 pm
Candyman's Avatar
Smile Re: Inside door handle won't work 2006 PT
Hey their gminfla,
Welcome to the Forum. One other thing you might check really quick, their should be a little white switch about half way down the inside of the door for the Child Safety Lock which will lock the inside of the doors. I have accidentally triped mine a couple of times.
Let us know if you don't figure it out.
Candyman
Check out my Custom PT Club Website: http://westvalleyforum.proboards.com/index.cgi
And my ever growing PT Photo Archives: http://s458.photobucket.com/albums/q...uiserArchives/
Please Like my Hot Rod Restoration and Detail Shop on Facebook.
https://www.facebook.com/BlueDiamondDetailing
Old 21 Aug 2009, 05:01 pm
Knotsobright1's Avatar
No child safety locks on front doors only back.
You can disassemble an entire PT with a 10mm wrench. So where did it go!
Old 22 Aug 2009, 11:13 am
Thanks, but I've been struggling with trying to remove the door panel for the last hour. Help again! I've removed the 3 screws, is there a trick involved? Please advise.
Old 22 Aug 2009, 11:22 am
Candyman's Avatar
Hey their gminfla,
Let me know if you haven't gotten it yet, and Ill walk you through it as you are 100% correct! My bad.
Thank you their Knotsobright1. I recon I'll have to change screen names with ya here for a bit.
Candyman
Old 22 Aug 2009, 02:32 pm
Here's what your gonna have to do. Push hard on the outside of the door at the door handle. Kinda lean on it like you closed the door and locked it but it didn't latch all the way. Know what I mean. While you're doing that you will have to work the handle to get the door open. What happened is the door is not 100 percent latched and it had disengaged the release. You will basically have to close the door a little more to get it too open. Kinda like having to go left to turn right.
Do "KLEEN WHEELS" really work??? Gary04GT Wheels, Tires, Suspension 15 12 Oct 2008 07:44 pm
2006 PT Street Cruiser Route 66 Edition skylight PT Cruiser News and Rumors 35 17 Nov 2007 02:39 pm
Employee Pricing on remaining 2006 PT Cruisers skylight PT Cruiser News and Rumors 0 09 Jul 2006 12:29 pm
2006 PT Cruiser Pics and New Specs skylight PT Cruiser News and Rumors 14 13 Nov 2005 08:46 pm
