How do i use a tap and die to remove oil plug?
Old 23 Aug 2009, 05:49 am
Default How do i use a tap and die to remove oil plug?
hi
i've been advised to use a tap and die to remove an oil plug from my PT, but i have no idea how, can any1 help me please?
Old 23 Aug 2009, 06:09 am
Default Re: How do i use a tap and die to remove oil plug?
You do not use a tap and die to remove the plug. You use it to fix the damage threads. If you do not know how to use a tap or die, this is not a job for you to fix. If not done right it will leak 24/7 and you could end up needing a new oil pan. $$$$$$
Old 23 Aug 2009, 06:34 am
i dont know what to do everything ive tried i just cant get the oil plug outand ive put engine flush in to.
Old 23 Aug 2009, 12:09 pm
You can't get ahold of the plug?Vise grips,pipe wench?I agree,maybe you would be better off having some one a little more mechanically incline check it out.JMO
Old 23 Aug 2009, 12:40 pm
fastdel's Avatar
Send a message via MSN to fastdel
as above take car to a good local garage as thay will have had this problem before and will have it removed in no time with damaging anything
ALSO KNOWN AS JCCC
Old 23 Aug 2009, 01:01 pm
They have a engine flush in it so I wouldn't recommend driving it. At this point you have a couple of options: have some one weld a nut on it or drilling a hole in it, then use a "easy-out" and try that. BTW using the welder, just using heat may "unstick" it enough that you might get a grip on it.
Old 23 Aug 2009, 03:14 pm
ive sorted it now. we had to take the oil pan off. tried welding a nut to it and the weld gave in first. even with the oil pan off and 2 mechanics with me the oil plug doesnt come off. it bent a claw hammer.
Old 23 Aug 2009, 07:11 pm
ejstith's Avatar
Damn, what do they have for an oil plug? Isn't it just a bolt? If it's not then it should be.
Old 23 Aug 2009, 07:17 pm
Drill the sumbeetch out!
Old 23 Aug 2009, 09:55 pm
A new oil pan in the works, or drill & retap this one...?
