Can you change the oil on a PT without jacking the car up?
Old 27 Aug 2009, 05:36 pm
Default Can you change the oil on a PT without jacking the car up?
Can you change the oil on a PT Cruiser without jacking the car up? thanks!
Old 27 Aug 2009, 05:48 pm
Default Re: Can you change the oil on a PT without jacking the car up?
Is that a trick question? How thin are you? Can you slide underneath the car and still breath, if so, the answer is yes.
I guess doing it that way you don't have to worry about the PT falling off the jack.
Old 27 Aug 2009, 06:13 pm
Send a message via AIM to rte662006
I do my oil change with out a jack.My street is on an angle but the sidewalk is level.So i put the 2 passenger tires on the curb and i am able to slide under the car no problem...and my pt is lowered.So it can be done if you have the right conditions i guess
Old 27 Aug 2009, 06:47 pm
Get a set of ramps, Wal-Mart etc. they will lift the front enough to be able to work under it.
Old 27 Aug 2009, 07:00 pm
I use ramps. More than enough room.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 27 Aug 2009, 08:52 pm
Choose wisely grasshopper....
I had a set of steel ramps - angle was too steep - Rhino ramps are great - plastic and only about $20.
Old 27 Aug 2009, 09:46 pm
Rhino ramps are what I have.
Old 27 Aug 2009, 09:58 pm
I back up my car on my steel ramps, then jack up the front and set it on Rhino's, tons of room for me on my creeper, and I'm a big fat guy!!!
6'2" and 285lb
Old 27 Aug 2009, 10:54 pm
mopar_man's Avatar
I don't have any ramps but my car is lowered and I'm fat so I need to jack the car up to get under it. Even when it wasn't lowered, I couldn't fit under it.
1973 Barracuda
340/auto
Modifications: Too many.
2002 PT Cruiser
N/A 2.4L/5-speed
1989 Caprice Wagon
307/auto
Old 28 Aug 2009, 11:39 am
wheelgarage's Avatar
Get the neighbors kid to help you out.....they can fit.
My PT is lowered also, so I use the ramps I bought from Walmart. Those work perfectly fine.
2005 Touring Black - Automagic....California Smog Legal
H&R Cup Kit | TSW Sakata 18x8 35ET | Nankang NS-II 235/40/18 | SPC front alignment cam - rear shim | Master Pro Rotors | Master Pro Ceramic F/R pads | Rebuilt Cylinder Head - Safety Valves and Guides | Felpro Head Gasket and upper rebuild kit | Fail-safe 195 degree thermostat | Mopar Waterpump...lol | 3rd radiator fan motor | Gates timing belt kit | WIX filters (oil, transmission) | Mobile 1 5w30 | Mopar ATF4 | Redline Water Wetter | K&N Drop-In | 4th Drive side Axle | Energy Suspension Torque Mounts | 3rd set of Torque Mounts...
Manual Transmission Fluid Change matt87951 Tech & Performance Forum 22 11 Apr 2011 03:42 pm
OIl Change Interval fifilund General Turbo Discussions 51 02 Feb 2004 03:29 pm
How to change the oil in your PT Cruiser... Gary04GT General PT Cruiser Discussions 7 06 Nov 2003 10:54 pm
Safe jacking GTSteve General PT Cruiser Discussions 9 05 Nov 2003 04:31 am
