New Multifunction Switch but still no indicators/hazards. Please help!
Old 28 Aug 2009, 10:47 am
Default New Multifunction Switch but still no indicators/hazards. Please help!
Good evening. I'm currently having a bit of trouble and I thought someone may be able to help.
I've had a search through the forums and firstly tracked down my non-functioning indicators/hazards were probably down to a faulty multifunction switch as both the fuses are OK. I purchased a new indicator/wiper setup, albeit from a mk2 neon, but was assured by Chrysler is was the same. But I still havnt got function of my indicators/hazards. All of the lights light-up when I lock/un-lock the car, so I guess the fuses are good.
Also, only the rear fog light functions, the fronts DO NOT.
Could anyone shed any light on this?
Many thanks in advance,
Kind regards,
Liam
Old 28 Aug 2009, 11:05 am
Default Re: New Multifunction Switch but still no indicators/hazards. Please help!
There's a "module" (relay) that clips on the switch. Compare old and new switches - often new switch doesn't come with relay, you have to move it from old to new.
Old 28 Aug 2009, 11:21 am
Thankyou, quicksilverdon.
However, I did recieve a relay with my new switch and tried both the old and new. Still no go
Old 28 Aug 2009, 11:30 am
All the bulbs - front & back - have 2 filaments - the signal is a separate filament from the "blink" when you unlock - might still be a fuse, so check - I'd start with fuse panel underhood by battery.
Old 28 Aug 2009, 12:08 pm
Thankyou, again.
I've replaced/swapped both the relavant fuses both in the engine bay and under the steering coloumn. Also, did notice that the bulbs have double filiments but read through the owners manual and it stated there would be a light displayed on the dash if a bulb had broken/blown.
Not a sign of this, so assume all bulbs are OK.
Also, just a thought, when the old multifunction switch blew it has 'melted' the connection block to the switch slightly, although all of the exiting wires are fine, not sign of excessive heat on the wires, only the connector.
Thankyou
Replace Multifunction Switch w/fog lamps Premiere General PT Cruiser Discussions 168 28 Jul 2019 12:52 pm
Multifunction Stalk (switch) CREWZIN Tech & Performance Forum 33 01 Dec 2014 01:58 pm
MultiFunction Switch Issues-HELP !!! jmack General PT Cruiser Discussions 10 26 Mar 2012 01:58 am
Multifunction switch jaball0 Tech & Performance Forum 1 03 Aug 2007 08:03 pm
Multifunction switch for postage Shini Quiet Classifieds: For Sale/Trade 0 23 Sep 2004 10:29 am
