2002 pt Cruiser
Old 30 Aug 2009, 08:55 pm
Default 2002 pt Cruiser
I have a 2002 and the car is overheating .I replaced the radiator cap t-stat and low speed fan relay.It's still doing it.I can't get the fan to come on .Also when I went to the parts store the worker suggested to replace the module he claimed it was a dealer part only and it was behind the right side head light anybody ever replace this part .Also how can I trouble shoot the fan.I don't want to just swap out parts if there still good.
Old 30 Aug 2009, 09:38 pm
Default Re: 2002 pt Cruiser
Welcome.
Odds are it's the fan itself. With car idling, switch on A/C - fan should come on. If it doesn't
Do a search on fan or overheating....
Old 30 Aug 2009, 09:43 pm
Thanks
Old 31 Aug 2009, 06:32 am
Mopar, Chrysler, Dodge, and Jeep parts wholesale prices
I found this and I see the module is part number 8 at the bottom of the fan has anybody found this part to be the cause of the fan not coming on.
Old 31 Aug 2009, 06:42 am
This is a pic
Old 31 Aug 2009, 07:49 am
Hi. Not sure what "module" your talking about behind the headlight. I think that person must be thinking about a different car. You have two fan relays inside the fuse box that's in the engine compartment (high and low speed fan) the coolant temperature sensor by the thermostat and the PCM itself. They all control the fan. The fan motor itself had a single wire harness that is about 10 inches long and goes into a connector at the back of the fan It's reached from getting underneath the car. Pulling the connector apart, you can put a positive and negative wire to the part of the connector still leading to the motor. The fan motor should start. If not, the motor is probably burnt out. You can buy the motor separately or the whole motor and shroud with fan blades, but either way, the whole thing has to come out of the car to fix it. I've put a sticky on the top of the Tech & Performance section of this forum to help you step by step in removing the fan.
Old 31 Aug 2009, 08:14 am
Fan module, pt cruiser 01-02 $329.00 $238.37
It looks like it's at the bottom of the fan part # 8 on the drawing I attached .
Old 31 Aug 2009, 08:51 am
No#8 is the whole fan and shroud. It's not at the bottom, it's pointing to the whole assembly of the shroud and fan. Here a link from eBay. You can pick up the whole thing for $83.99 plus FREE shipping. There is NOTHING behind the right headlight!
01-05 PT Cruiser RADIATOR COOLING FAN motor 04 chrysler:eBay Motors (item 230364505553 end time Sep-04-09 17:50:28 PDT)
Old 31 Aug 2009, 10:38 am
I put a multi-meter on the fan and I'am getting resistance of 17 ohms ,I think the fan is still good.I believe it would read infinitiy if the fan was toasted.
Old 31 Aug 2009, 10:48 am
Also I pulled the low demand fuse and the fan turned in high,and the car threw code p1490 Low speed fan control relay circuit.not sure but when the relay is blown it should throw a code.Maybe the pcm is not giving me a signial or the wires a bad coming out of the fuse block.They are black yellow and green
FS: 2002 Chrysler Dream Cruiser #0076 addsmack Classifieds: For Sale/Trade 14 27 Aug 2009 08:04 am
2004 Chrysler PT Dream Cruiser Series 3 skylight PT Cruiser News and Rumors 10 18 Jun 2009 08:57 am
Exterior Mod List slayerdarkcross Exterior Accessories Forum 8 22 Jul 2008 03:54 pm
2002 Chrysler PT Cruiser Dream Cruiser Edition**Loooaded*** (hayward / castro valley) skylight craigslist 0 10 Jul 2007 02:30 pm
New 2005 Convertible PT Dream Cruiser skylight PT Cruiser News and Rumors 4 11 Jan 2005 06:12 pm
