PT Cruiser Tires
Old 06 Sep 2009, 11:13 am
Default PT Cruiser Tires
I just got some 16inch rims for my PT Cruiser. What tires would i need? Right now I have 195/65 15inch rim. Thanks! I heard it is bad to put bigger rims to the car. Anyone know why? Thanks!
Old 06 Sep 2009, 08:42 pm
808's Avatar
808 808 is offline
Default Re: PT Cruiser Tires
The basic size is 205/55 16 to keep the speedometer/odometer accurate.
And of course putting bigger rims on a car makes it bad. Well actually the main reason would have to be the fact that you will be having a shorter sidewall for the tires so you'll expect a little less comfort while driving.
Old 06 Sep 2009, 09:21 pm
yaris's Avatar
its not bad, well it depend of your point of view, yes when going with a bigger rim you give some confort away, but you gain some control. with my 17inches rims and sonar sx1-evo tires it now turn the curves way better than the stock tires/wheels, plus the steering is more precise, but every hole hit more, its a compromise to do between confort and performance....
Old 06 Sep 2009, 11:26 pm
Thanks! You know any good tires for a PT Cruiser (one that is good for everything: rain, comfortable ride, snow, etc.) Thanks!
Old 07 Sep 2009, 01:44 am
808's Avatar
808 808 is offline
Right, the fact that you can upgrade the tire brand/model helps.
If I were you, I'd do some research for that by looking at tire reviews on
Tire Rack - Tire Reviews and Ratings
1010 Tires - Tire Reviews & Ratings
Old 07 Sep 2009, 11:51 am
Windancer's Avatar
As long as they have the same diameter (to keep the speedo & odometer correct)they should be fine. I have 205/55/R16 as my stock tire and I put 225/50/R16 on my 'Vert and they both have a diameter or 24.9".
Terry
2005 PT Cruiser Convertible - Touring Edition - Black
Mopar Spoiler, Mopar Ground Effects Kit, 16x7 American Eagle Chrome 5 Spoke Wheels, Toyo Proxes 4 225/50/R16 High Performance Tires
Autotechnica Chrome Shifter & Autotechnica Chrome Shifter Kit, Sony Headunit
Old 07 Sep 2009, 01:23 pm
How do I measure the diameter? Can you specifiy more (sorry, I am not that good with geometry). How do bigger rims make a less comfortable ride? Shouldn't it be more smoother and comfortable? Thanks!
Old 07 Sep 2009, 01:34 pm
Is the Michelin Primacy MXV4 91H tire any good?
Old 07 Sep 2009, 08:46 pm
yaris's Avatar
its because a tire also act a bit as a shock, so the less sidewall you have, the less shock the tire give. plus usually with bigger rims(and less sidewall) you need to run a higher tire pressure which make the tire act even less as a shock
Old 08 Sep 2009, 01:31 am
Windancer's Avatar
You don't have to be a brain surgeon to measure the diameter of a tire. According to Tirerack (Tirerack.com check it out for yourself), your tires which are 195/65/R15 tires have a diameter of 25" and should be on rims that are between 5.5" to 7" wide. How wide are your 16" rims?
Like I said befor my new 16" rims are 7" wide and I hve 225/50/R16 tires on it and the diameter is a wee bit greater than 24.9" which is close to 25" in diameter.
New PT owner in south Wisconsin ADR General PT Cruiser Discussions 22 21 Aug 2009 07:56 am
Comparing the BMW Z4 to the PT Cruiser GT robinjoe General PT Cruiser Discussions 8 16 Aug 2009 10:11 pm
'Re-energized' PT Cruiser? slayerdarkcross PT Cruiser News and Rumors 4 03 Aug 2009 10:47 am
Help! Badyear tires strike again! SRG General PT Cruiser Discussions 40 20 Apr 2009 10:27 pm
FS: HUGE Wheels and Tires Lot ptcruzin42 Classifieds: For Sale/Trade 4 06 Jun 2006 10:41 pm
