Can't find the answer to this code
Old 07 Sep 2009, 10:36 am
jennylyn's Avatar
Default Can't find the answer to this code
I cannot find the definition for the P140 code. I've had so many problems with my '01 PT Cruiser, just got it back on the road 2 days ago after an engine rebuild, this code started yesterday after we had put about 100 miles on it. It seems vaguly familiar, but I don't remember what it is
Old 07 Sep 2009, 11:35 am
Default Re: Can't find the answer to this code
Oxygen sensor fault code (when you look up the code it should have 1 letter and 4 numbers (P 0140
P0140 HO2S Circuit Insufficient Activity Bank 1 Sensor 2
Check to make sure whoever rebuilt your engine replaced and hooked up the 02 sensor.
Old 07 Sep 2009, 11:36 am
jennylyn, there has to be another number for the code. Did you get this code using the key "trick". I would suggest you take it back to the person who rebuilt the engine.
Old 07 Sep 2009, 03:09 pm
If it is p0140 then it's not really the engine builders fault. It's the 02 sensor thats worn out. What happened to the engine to need a rebuild?
the dreaded p0551 code - stumper djfox1 Turbo Performance 17 16 Apr 2016 08:14 pm
Code 2094 Camshaft Position Actuator bank 2 low PTGUY_PSL Tech & Performance Forum 0 27 Dec 2008 08:46 pm
Looking For An Answer On Code Sassy General Turbo Discussions 6 15 Dec 2008 05:10 pm
NEED CODE ANSWER SHERRI Tech & Performance Forum 7 27 Jun 2004 10:27 pm
P 2302 Fault Code unable to find Turbo Red General PT Cruiser Discussions 2 08 Feb 2004 12:37 am
