I need to know which fuse is for my power windows in my 2005 turbo conv. pt. The manual and diagrams don't tell me which one unless I'm missing something? Please help!!
sure do appreciate the reply. I'll give her another check for the 30 amp. Had to put her away because of the rain. The window has a little feature with the convertibles where it opens up a 1/2 inch every time you open and close your door to clear the rag top. Well you guessed it. Since my windows wont move they are stuck on the outside of the softtop instead of being up and in them where they belong. Rain gets in real easy that way. Hopefully I can figure this out before I have to take to dealer. Thanks again. Still diggin my cruiser.
Get in and raise your top 1", close your doors and put the top back down. Now you're stuck in it, but at least it's dry...lol... I had this happen once, one of my door switches came loose (hit a magnificent pot hole that day) and I cleaned out my trunk, laid down my back seats, and used my trunk for entrance and exit until I figured it out. You should see a 6'2" tall guy at 280 lbs climbing in and out that way! Sure sparks a lot of laughter...
There's an entire section on troubleshooting the windows. Might be of help. Will post them here, may take two entries due to file size, but they should help you out.
Edit, will post from my hosting domain since this site has such wonky low attachment levels...excuse the long post, but you can right click on the images and save them to your puter... ... ![]() ... ![]() ... ![]() ... ![]() ... ![]() Since both sides are not working, the only thing I see tied to both is that breaker I mentioned one post above. The driver and passenger door modules are completely separate, as is the wiring up to that breaker. If you read through the service manual, the fuse block shows the breaker rated at 20 amps and the documentation following that says it's a 30 amp. Guess they couldn't make up their minds. Last edited by Chromenut; 07 Sep 2009 at 08:32 pm. |
i was changing out my cam sensor, i dropped my negative cable from the battery as suggested, after putting everything back together had no power windows. and checked Manuel for fuse location in the fuse box and it wasn't listed and any online picture does not match my fuse box.
i have a 2005 2.4l turbo pt cruiser. any info would help thank you
| 03 Cruiser PWR Window Problems. Help!! | Slayer213 | General PT Cruiser Discussions | 7 | 10 Feb 2012 01:59 pm |
| Ignition Off Draw (IOD) Fuse Effects and Replacement Hints | ObiMatt87 | Tech & Performance Forum | 15 | 24 Apr 2011 03:41 pm |
| Window Mirror Issue Window won't go up | georgebIV | General PT Cruiser Discussions | 2 | 09 Aug 2009 01:17 pm |
| Hello and Please help with Fuse location | DelValPC | Tech & Performance Forum | 2 | 01 Jul 2008 02:28 pm |
| Autometer gauges | PTGT Redman | Turbo Performance | 12 | 23 Jul 2003 09:08 am |
