Why is there water in my headlights?
Old 14 Sep 2009, 09:34 pm
William_F's Avatar
Default Why is there water in my headlights?
Of course the obvious answer is there is a leak somewhere in but can someone help me figure out how to find and fix it?
Does the whole assembly have to be replaced or is there a gasket or something that can be replaced?
What should I do to fix this problem?
Old 15 Sep 2009, 12:00 pm
Default Re: Why is there water in my headlights?
I have read of people taking the headlights apart - some to paint the silver part, some take out the yellow refletors - anyway, go along the seam with a heat gun, loosen up the "goop" that holds the 2 halves together.
I would think a good warming with the same heat gun would dry up moisture, then put a bead of silicone caulking on the halves and re-join.
Old 15 Sep 2009, 12:38 pm
William_F's Avatar
Thanks for the tip!
I don't own a heat gun, but at least knowing the lamps can be disassembled and won't have to be replaced is a good thing
Old 15 Sep 2009, 02:39 pm
Try a hair dryer on a hot setting, a heat gun really puts out the heat and may melt parts. Someone on this board heated it in the oven, I don't have the times etc to tell you.
Old 15 Sep 2009, 06:35 pm
03GTCruiser's Avatar
I may be remembering incorrectly, so please search before you do. I believe they bake them at ~ 200F for 5 to 7 minutes*.
*Keep in mind oven temps may vary, so adjust cooking times as necesary.
2003 Pt Cruiser GT Autostick.
http://www.ptcruiserlinks.com/forum/image.php?type=sigpic&userid=9656&dateline=1247691  818
Ran 14.84 on my 5th run EVER down the track with the help of a fellow PTer and his 93 tune on his DSP.
*Stage 1, DSP w/93 canned tune, 3" o2 housing, 3" FWDPerformance downpipe with cutout. Bwoody solid mounts. AMX1397 TTAB with K&n drop in filter and airbox mod. Soon: AMX1397 lower pipe and AMX1397 uppipe with HKS BOV
* stock nsrt rims powdercoated black, chrome pillars.
* 3 gauge pod w/ aem wideband, Autometer ultralite oil pressure and 30/30 boost, Mopar 8" sub.*
Old 15 Sep 2009, 07:54 pm
Chromenut's Avatar
Go to PTCrew.com, there's a mod bible entry on removing the amber reflector out and it tells you exactly what temp to bake them at. And yes, it works!
Old 17 Sep 2009, 01:13 am
If all else fails there is a good after market replacement for $155.00 thats about half the dealer cost.Allso Ron and John have done it in the oven ,John is Slayer darkcross.:bore d::yah oo:
Old 17 Sep 2009, 01:47 am
Send a message via AIM to slayerdarkcross Send a message via MSN to slayerdarkcross
Yup we own a surf shop
Both sets of headlights were baked while intoxicated and it worked!
2007 Touring Edition
Exhaust: Borla
Front: ODaddyO
Headunit: JVC KD-AVX77
Hood: ODaddyO
Intake: K&N Airraid
LED's: Oznium
Rear: ODaddyO
Speakers: Polk DB6501
Springs: Gold Line Slammers
Strut Bar: BTG Turbo
Subwoofers: Alpine SWR-1243D
Tailights: United Pacific LED Teardrop
Visor: Cal Cruiser
Check out my progress
My Facebook Add me!
Detailing How to Guide Washing your PT Candyman The Detail Shop 1 01 Aug 2008 03:16 pm
Water in foglights and headlights. DJmart General PT Cruiser Discussions 3 13 Oct 2007 10:52 am
Check & drain you water heaters, A/C , &.... Espresso Non-PT Discussions 17 12 Jul 2005 11:47 am
Water dribble while waxing robinjoe The Detail Shop 5 13 Aug 2004 11:25 pm
water Jimbo Non-PT Discussions 3 12 Aug 2004 07:30 am
