I have another thread on this problem but started this one the title will help me find someone that knows the proper way of testing a coil. Sorry if it causes any problems.
My daughter has a 2000 PT Crusier that just quit all of a sudden on her while driving down the road today. It looks like it's getting fuel but no spark at the plugs. I only used a screwdriver in the boot trying to ground it on something metal. But i didn't see any spark at all on the two outside plugs. How do you test the coil and the harness going to it? I did read where often times it is not the coil but it just another thing i want to be sure of before buying a part i don't need. |
I did quite a bit of research on this last night and found the the ASD would shut down the motor if it lost signal from either the cam sensor or the crankshaft sensor. So i figured it probably wasn't the coil. More likely something telling the ASD to shut down the spark and fuel.
Swapped the ASD relay with the horn relay first of all. That didn't help so i figured the relay was good. Error code told me crank sensor, so i checked it and found a broken wire had rubbed the rack and pinion for too long. So it turned out to be an easy fix. |
Well, i probably wont get back underneith her car until the next problem. But it was behind the motor, right in the middle down low by the oil filter. The harness just kinda hangs down there. Harness go to the crankshaft position sensor, the alternator, and the starter. The harness was rubbing against the rack and pinion boot.
Obviously the harness wasn't secured by the previous owner. There was already one wire in the same exact place that had a butt connector from the same thing. But they didn't even secure the harness out of the way afterwards. You would think they know better. |
I had the same thing happen to the wiring harness of the Camshaft Position Sensor years ago. The harness runs behind the engine and it was held on by a $.02 clip which broke and let the harness hang down and hit a moving part ( half shaft) and burn the wires. PT came to a dead stop traveling threw South Carolina on a major highway at 11pm.
Overnight in a motel, next morning towed to a Chrysler dealer and mechanic found the burnt wires when he was about to change out the sensor & whole harness. Fixed the wires instead and only cost 2 hours labor and a day in my life. The estimate was $200. Blurry picture from my cell phone.
| Ignition coil problem...maybe? | pcm2a | Tech & Performance Forum | 19 | 06 Sep 2011 09:04 pm |
| Ignition-Off Draw test | oldcoach | General PT Cruiser Discussions | 0 | 27 Oct 2007 04:57 am |
| Stage 1 passed TX emissions test | JohnM | Stage Turbo Kits | 6 | 11 Jul 2005 04:55 pm |
| Screamin Demon Coil and Howell Automotive | snakepitt1 | Tech & Performance Forum | 4 | 21 Jun 2004 11:44 pm |
| test | Gary04GT | Testing | 0 | 25 Mar 2003 04:18 pm |
