Air Conditioning Problem?Advice Please
Old 22 Sep 2009, 09:26 pm
Default Air Conditioning Problem?Advice Please
Hi .............as you know........I had my timing belt, water pump..........and than a leaking powersteering pump changed.........now in 30 degrees Celcius weather I noticed my AC is now not blowing cold like it did before the repairs.........what would cause this? Is the Ac somehow tied into the previously repaired systems?.........Just one problem after another.....
PT Cruiser Inferno Red GT Cruiser. 5Spd 215HO HP 17" Chrome wheels, Chrome gas cap, door spears, door handle cups, door buttons,door lock pins, vent covers,rear spoiler,rear painted mudflaps,, chrome/carbon fibre/like ebrake cover, wiper jet covers,bra, seat covers,Mr. Mikes welting, chrome valve stems and caps, leather ebrake boot,chrome change holder cover,black/red leather steering wheel cover, chrome antenna bezel and chrome 12:" antenna,rear quarter window decals, winter car cover for winter storage, special made DREAM CREWZER dash plaque.upper windshield eyebrow tint , gts headlight protectors, carbon fibre taillight covers,car cover,K&N drop in filter, AMX intake pipe, shiny metal steering wheel spoke covers:Mopar door sills, rear chrome licence insert.street series badge,billett grill,engine start button, red brake calipers,painted engine manifold,chrome vent knobs,chrome/carbon fibre shift knob
Old 22 Sep 2009, 09:27 pm
Default Re: Air Conditioning Problem?Advice Please
p.s.......I'll call my mechanic again tomorrow
Old 22 Sep 2009, 09:43 pm
I have done a search...when I start turning the engine on ...than the ac on I don't hear the compressor come on nor the idle jump....could it be a fuse?
Old 22 Sep 2009, 10:32 pm
Ok....so I turned the engine on again and than turned on ac no sound of compressor coming on nor a idle jump.....i switched the horn relay with the ac relay as they are the same and the horn works but this did nothing....so I put the relays back to where they were.......not sure what to do next. Also looking at the fuse box/relay box under the hood and my manual.....my car does not have a relay in the "E" location.....it shows in the manual"Radiator Fan Relay High Speed"....it is empty with no relay....is my GT supposed to have it? I have read about fans...relays....compressors....etc....just don't know what the problem is? Help needed please
Old 23 Sep 2009, 06:04 am
When the timing belt etc. job was done, was your a/c hose disconnected or loosened? You may have lost Freon IF that was done.
Old 23 Sep 2009, 09:23 am
Service Manual states that the AC tubing, accumulator (or whatever its called) need to be disconnected to do the timing belt. It is not absolutely necessary but I'm willing to bet it was done.
You may have lost freon, mechanic may have missed something putting it back together.
In my opinion the mechanic should put everything back together right and you shouldn't be charged.
BTW if he tries to sell you a compressor or really anything at all he is either full of it, or broke it taking it apart and he's trying to cover his losses.
He might have filled it up with freon, but maybe there was a leak and it came back out. I would think this is his responsibility too. He's had his hands all over the AC system in any event.
Old 23 Sep 2009, 02:55 pm
Phil,
Don't worry about the fuse for the high speed fan. On the Turbo's (don't know if it included the turbo lite) the fan works by the computer and you have a variable speed fan. On the Non-turbos, the fan is either high or low so you have two relays.
Leaned that from MX-5.
Old 23 Sep 2009, 03:21 pm
Tanx fellas...I spoke to my mechanic and he said he didn't touch the ac system but than he corrected himself and said he did touch the ac lines...I am going in to see him at 08.30-9.00 am tomorrow. He said he may not have tightened something...he also mentioned something about a o ring and lost freon.......got to stay on top of these guys...............took ity in for one problem...coolant loss and overheating and got 2 more problems............pisses me off as today is 33 celcius+.....hot hot hot....sweaty...sweaty.............guess I will have to drive with windows down.....probably get the ac fixed just in time for winter
Old 23 Sep 2009, 03:31 pm
As long as you get it fixed for next year.
Old 23 Sep 2009, 10:38 pm
Matt42's Avatar
I hear ya. Got up to about 43C here this summer. Cooler than last year, though, and the year before was worse.
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, [Now gone 2004 PT Cruiser Base 5 speed], 2007 Chrysler T&C Touring
Timing belt kills air conditioning customer20 General Turbo Discussions 9 19 Jul 2009 08:19 pm
Air Conditioning turbokidd General Turbo Discussions 8 24 Nov 2008 09:35 am
Air Conditioning Beef-Up TaylorMade General PT Cruiser Discussions 10 14 Mar 2005 12:25 am
Air Conditioning not very cold? Curruzr General PT Cruiser Discussions 7 16 Aug 2004 05:22 pm
air conditioning ARNOLD BROWNE Tech & Performance Forum 9 19 Aug 2003 08:04 pm
