Oil filter for new PT Owner
Old 23 Sep 2009, 03:12 pm
Default Oil filter for new PT Owner
Where is the oil filter located?
Old 23 Sep 2009, 03:35 pm
Default Re: Oil filter for new PT Owner
Raise the front end of the PT, I believe it is on the driver's side. Trying to remember () when it was on the lift when I last had the oil changed. It is very visible tho when the PT is on a lift.
Old 23 Sep 2009, 03:46 pm
yaris's Avatar
as holligan said, it will be very visible from under the car. for its position, it is just a little on the passenger side behind the engine, pretty mush at the same level as the plug and close to it, and very accessible
Old 23 Sep 2009, 03:53 pm
Easiest car to change the oil I have ever owned next to V-8 Chevies from the '60's and up.
Filter is right there by the drain plug.
I use Mobil 1 synthetic media filter M1-209, one of the best brands out there.
Old 23 Sep 2009, 03:58 pm
Old 24 Sep 2009, 07:44 am
Agree with all that...
I drive it up on ramps to get to it easier. - warms the oil up (from cold) just enough to flow but not too hot to handle in a plastic container.
2005 Limited Turbo-Lite, auto in Cool Vanilla
Old 24 Sep 2009, 10:38 am
We are from the same cloth - except I like the rig good and hot - easier removal of filter.
LOVE my RHINO ramps - use them all the time - even just to get the car up to working height when changing spark plugs - or wash/wax you name it!
Old 24 Sep 2009, 11:12 am
Crewzin, this is great. A picture is worth a thousand words. I'm all set as soon as I find a Cadillac horn I can install in my PT.
Old 24 Sep 2009, 11:18 am
Most of us went with an Ahooga Horn, but I guess a Cadillac horn would be different. You might be able to stick it right where the OEM horn is (right fender).
Old 24 Sep 2009, 11:22 am
Mobil One Oil 0w30, Mobil one filter M1102 is the right one for a 2001 base (N/A), M1209 for a 2004 Limited (turbo).
Cabin air filter AlmondTurbo General PT Cruiser Discussions 44 27 Jul 2012 06:31 pm
OIL FILTER SANDWICH GALVANIZEDYANKEE General Turbo Discussions 5 11 Sep 2009 01:31 pm
airbox foam breather filter, DIY replacement ptandme General PT Cruiser Discussions 2 14 Oct 2008 11:34 pm
K&N filter oil on BTG filter? Punch Turbo Performance 1 15 Oct 2003 11:55 pm
