Rough Idle only with AC on
Old 02 Oct 2009, 04:30 am
Default Rough Idle only with AC on
hello folkes,
i recently purchased a 2001 pt cruiser with 94,000, it was one owner, well cared for with mainly highway miles between florida & ohio. it runs great EXCEPT when the ac is on, then i get the rough idle & burps, especially when stopped at red lights or mc donalds drive thru i bought this car because i have not been able to find employment since december, with the rotten economy and being in florida, hence i do not have a lot of $ to try different diagnostics. my jeep liberty has to go back to the repo man i can't make any more payments.
would plug wires cause this? i have already replaced the battery because that sounded weak, i don't have a lit more cash to play with right now.
thanx very much for any help
beachpatty
Old 02 Oct 2009, 06:34 am
Travis2k7's Avatar
Default Re: Rough Idle only with AC on
With that kind of mileage did you get any kind of maintenance records? You are in the ballpark for the timing belt job which is in the $1000 ballpark assuming it hasn't been changed yet.
2006 Limited, Auto, 100k miles
Old 02 Oct 2009, 07:11 am
Beachpatty, welcome to the forum.
Agree with Travis. Buying a PT with that kind of miles, hopefully there was some kind of maintenance record.
As far as the rough idle with the A/C on, does the temperature guage raise over halfway when your sitting for a few minutes with the A/C on? If it does, your problem could be your fan motor. If it stays at the halfway mark then a simple change of plugs and wires might help considerably.
Rough idle 03 GT elmeyer Tech & Performance Forum 2 03 Jul 2009 09:44 pm
Rough Idle, Rough @60, check engine light NEW Dystroy Tech & Performance Forum 8 12 Jan 2009 09:07 pm
rough idle on 01 2.4 Davestone General PT Cruiser Discussions 8 26 Mar 2008 09:52 pm
Rough Idle BlueBlurCruiser General PT Cruiser Discussions 15 07 May 2004 09:50 am
Rough idle PTPaul Tech & Performance Forum 1 17 Oct 2001 05:34 pm
