iridium spark plugs
  #21 (permalink)
Old 10 Oct 2009, 07:22 am
Send a message via Yahoo to sugees69
Default Re: iridium spark plugs
I always change the wires when I change the plugs. To me they go hand in hand. I want to get wire that last longer then 30k. I pretty the iridum plugs will last longer then 30k.
  #22 (permalink)
Old 10 Oct 2009, 12:05 pm
the iridum plugs last longer and the platinum last longer and the are great especially if you have really hard spark plugs to get to. But if your plugs are easy to reach use copper.Copper will transfer heat better they conduct electricity better. Copper gives you better performance. If you got one of those cars were you have to lower the transmission to get to the plugs hey a 100k plus plug is a great thing!
  #23 (permalink)
Old 12 Oct 2009, 12:32 am
sugees69: hi, just try it..
  #24 (permalink)
Old 12 Oct 2009, 07:35 am
New question. It has been suggested to me that I use 8mm or 8 1/2mm wire. Can I do that when the plugs are 7mm?
  #25 (permalink)
Old 12 Oct 2009, 12:03 pm
Matt42's Avatar
Yes. I did. I used MSD wires. Works fine. It's the OEM wires that are 7 mm. not the plugs.
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, 2004 PT Cruiser Base 5 speed, 2007 Chrysler T&C Touring
  #26 (permalink)
Old 12 Oct 2009, 05:23 pm
Correct. Fatter wires (as a rule of thumb) last longer (more insulation).
  #27 (permalink)
Old 13 Oct 2009, 07:37 am
Charon's Avatar
Exclamation Re: iridium spark plugs
G'day all,
This is a topic that is subject to many points of view..
Good research is a must b4 you comit..
I have used the Champion & the NGK as listed. in the past &
I do find it hard to compare, as I changed to Iridium,Livewires,Screemin Demon & 18v coil voltage upgrade, all in one hit.
May I say that there is a remarkable differance. & BTW I have opened the plug gap up to 55thou, combined with iridium 0.6mm electrode it is an electrifying combo.
in use now over 12mths NEVER misses a beat.
& she see's 5000+ every day of the week..
So in my opinion, "for what its worth" GO with the Iridium...
Cheers Andrew...
iridium plugs??? DARK270 Stage Turbo Kits 28 17 Jan 2010 04:02 pm
Champion Iridium Plugs rszappa1 Tech & Performance Forum 5 06 Feb 2006 08:09 am
gapping iridium plugs Hill Cruiser General PT Cruiser Discussions 4 18 Oct 2005 10:53 pm
Iridium Plugs luvmypt Tech & Performance Forum 9 19 Jul 2004 12:16 pm
Denso Iridium Plugs gsharrock Turbo Performance 2 22 Jun 2003 09:09 am
