Lower Radiator Hose Replacement on Turbo Engine
Old 08 Oct 2009, 09:26 pm
Default Lower Radiator Hose Replacement on Turbo Engine
I have a 2003 PT Cruiser 2.4L with the turbo. The lower radiator hose requires replacement. The spacing between the radiator and engine is tight, I cannot get in there to even touch the hose where it goes into the engine. The outlet from the radiator is tight too.
This car also has AC. How and what do I have to remove to have enough space to R/R the hose? Are there directions anywhere?
This should be a simple job, but I am just lost. Any help is appreciated.
Old 08 Oct 2009, 11:37 pm
Default Re: Lower Radiator Hose Replacement on Turbo Engine
My 2003 just got a new rad this week...the mechanic put it in...He had to take off upper grill...and upper rad support...to pull rad forward...not sure if this helps
2003 PT Cruiser Inferno Red GT Cruiser. 5Spd 215HO HP 17" Chrome wheels, Chrome gas cap, door spears, door handle cups, door buttons,door lock pins, vent covers,rear spoiler,rear painted mudflaps,, chrome/carbon fibre/like ebrake cover, wiper jet covers,bra, seat covers,Mr. Mikes welting, chrome valve stems and caps, leather ebrake boot,chrome change holder cover,black/red leather steering wheel cover, chrome antenna bezel and chrome 12:" antenna,rear quarter window decals, winter car cover for winter storage, special made DREAM CREWZER dash plaque.upper windshield eyebrow tint , gts headlight protectors, carbon fibre taillight covers,car cover,K&N drop in filter, AMX intake pipe, shiny metal steering wheel spoke covers:Mopar door sills, rear chrome licence insert.street series badge,
Old 09 Oct 2009, 02:08 pm
Did he do the upper or lower hose. I have all that apart and it is still very tight on the bottom. I can get to the upper, its the bottom with the turbo stuff and distance to the engine that's the issue. The radiator has a tab on the drivers side that stops it from moving forward. The radiator is also connected to some of the turbo routing, and its very tight.
Old 09 Oct 2009, 03:40 pm
Chromenut's Avatar
OMG there is a lot of garbage there! The service manual shows how to pull it but doesn't go into any specfics. Looks like there are other hoses that have to be removed first, not sure if it was tranny coolant hose or PS hoses... PM me and I'll get you some documentation....
2006 PT GT vert: Getrag 5-speed, wind spoiler, billet shifter, 15" billet antenna, chrome brake handle, LED tail lights, Typhoon intake, AMX upper & lower pipe, chrome curb trim, chrome headlight trim, PT sunvisor badges, chrome hood protector, chrome front & rear bumper addons, Mopar BOV, DSP & custom tune, JL Audio sub-woofer, 17x7 wheels...more...
Old 09 Oct 2009, 03:48 pm
Less engine oil/filter & tranny fluid/filter changes, air filter, plugs wires and some bulbs that you can do yourself easily....... Or something like the camshaft sensor that can be done yourself and goes out on a regular basis..... In the long run you are ahead in many ways having the stealership do the service.
This is one of those times IMHO.
Old 09 Oct 2009, 05:30 pm
This is what I was afraid of. Its in the garage and its become personal....but I may end of eating my pride to think a radiator hose can do me in.
If there are any thoughts it would be great. I did get a quote and they are only indicating its an hour or so of labor.
Any thoughts?
Old 09 Oct 2009, 05:45 pm
Chromenut's Avatar
REmove the radiaotor, problem solved
Old 09 Oct 2009, 05:52 pm
That was my first thought BUT. It has AC cooler that's connected to the radiator. The bolts connecting them have the same issue.
It would appear I need to break the AC line to remove it all. The whole thing is tied to the outlet of the Trubo.
Tags
hose, radiator, replace, turbo
Check Engine Light following Radiator Fan Motor replacement rigger45 Tech & Performance Forum 4 12 Aug 2009 06:46 am
Lower radiator hose change LMorano General PT Cruiser Discussions 5 14 Apr 2009 07:07 pm
03 Turbo Radiator Replacement hanks424 Tech & Performance Forum 3 04 Jan 2009 09:28 am
Radiator hose blew off jojo Tech & Performance Forum 6 16 Feb 2008 06:28 pm
Turbo Engine Replacement Bigphil3232 General Turbo Discussions 9 17 Nov 2004 05:43 am
  Find jobs | Free Movies | Wordpress Themes | Website Design | Recreation Sports Guide
